So im about to start replacing fluids back into engine since its all buttoned up only thing left to do is install battery and was wondering if my research has sent me in the right direction.
Power steering fluid =ATF
Oil/filter = Rotella T6 and Purolator pure one filter
Coolant = 1gallon Oem subaru w 1gallon distilled water and oem conditioner.
Sounds about right except the oil filter I prefer oem filters. The pressure in the valve of aftermarket ones is not the same as subaru. You could also throw some water wetter in there if you want.
Honestly I use Autozones 50/50 mix as far as anti-freeze and I still use Valvoline 5W-30 oil...Maybe I am lucky I guess...
