Rear Diffuser..help - Subaru WRX Forum
post #1 of 11 Old 09-22-2009, 12:51 PM Thread Starter
Subieboo204 is an unknown
Rear Diffuser..help
I understand its purpose for aerodynamics... but is it actually worth it?
Subieboo204 is offline
post #2 of 11 Old 09-22-2009, 05:38 PM
midniteblack's Avatar
midniteblack is more helpful than not
Send a message via AIM to midniteblack
well, what are aerodynamics worth to you? They do serve a purpose just like all of the other aerodynamic parts made for a race car, but i think a lot of people will never push their car that hard to even put their fancy front lips and diffusers to use.
midniteblack is offline
post #3 of 11 Old 09-22-2009, 06:28 PM Thread Starter
word thats what i figured but wanted to see if anyone swore by them...
post #4 of 11 Old 09-22-2009, 10:14 PM
aw... but I like my fancy STi Limited knock-off lip
Subieboo204, are you referring to the roof-mounted mini spoiler that comes on the older STis or the plastic under diffuser that sits behind the rear differential on the older STis? I'd love to get a rear under diffuser for my WRX. I just like the way it looks, although I think it might have to be trimmed if you upgrade your stock exhaust to an angled-exit big momma fart can or maybe if you get a larger aftermarket rear sway bar. I'm not terribly crazy about the looks of the roof-mounted piece though.
midniteblack is correct. For a daily driven street car, both of them are mostly about looks.
post #5 of 11 Old 09-23-2009, 01:04 AM
no hate here, i have one too! I'm glad i have the flimsy knock off or else it would have broke a long time ago if it was authentic.
post #6 of 11 Old 09-23-2009, 09:04 AM
Haha yeah, I've definitely scraped the bottom of mine a couple of times and my car's not even lowered, but the looks are killer. When I first installed it with the 6 or so screws that were provided, I saw that there were tiny little gaps between the bumper and lip where the plastic sort of wrinkled from the pressure between the screws. So... I secured it with about 40 extra screws and bolts all the way across and now the gaps are gone. That thing's not going anywhere. I think I might leave the lip on during the winter too. I was also tempted to run a line of clear or black caulk (or something similar) between the bottom of the car bumper and the top of the lip just to seal everything up completely, but that might not look so good because of the glossy paint being next to the flat finish of the lip and it would make things difficult if I ever do decide to take the lip off.
post #7 of 11 Old 09-23-2009, 11:33 AM
boostspike's Avatar
boostspike is more helpful than not
i have an 06-07 sti rear diffuser with the cusco subframe brace and i don't know if it very functional but it does suck up the dust on the road. i did have to cut it to fit my huge turboxs rfl axle back but my perrin 22mm sway bar clears with no problem im happy with it
there's a couple pics in my gallery
boostspike is offline
post #8 of 11 Old 09-24-2009, 12:50 AM
^ Good to know... thanks for the input
post #9 of 11 Old 09-24-2009, 03:47 PM
Do you upgraded sway bar mounts? From my understanding, it's those that the Cusco bar won't clear.
post #10 of 11 Old 09-24-2009, 04:19 PM
My whiteline sway bars clears my rear diffuser but my invidia exhaust rubbed on the front left of the diffuser and it melted a little bit off of it.
There is no way of noticing it unless you get underneath the car.
post #11 of 11 Old 09-24-2009, 10:58 PM
boostspike's Avatar
i have stock sway bar mounts
if you wanted to put a diffuser on you can get the weld on mounts from subaru i've seen them on subarugenuineparts.com
