Rallyarmor Mud Flap Install - Subaru WRX Forum
post #1 of 14 Old 12-29-2009, 01:56 PM Thread Starter
mfarnham's Avatar
mfarnham is an unknown
I just bought Rallyarmor mud flaps (02-07 ## Rally Mud Flaps Blue Logo) for my 2006 WRX. The instructions that came with them seem to only apply to the STi model. And their instuctional video is only for the STi as well. Does anyone know how to install the mud flaps on a '06 WRX? Thanks.
mfarnham is offline
post #2 of 14 Old 12-29-2009, 02:15 PM
I have a feeling the mud flaps would install the same way on an 02-07 WRX, 04-07 STi, and even the 02-07 Impreza 2.5 RS, for that matter. Have you noticed any major differences in the fender liner area between your WRX and the STi in the video?
post #3 of 14 Old 12-29-2009, 02:30 PM Thread Starter
mfarnham's Avatar
Yes, the side skirt on the STi continues all the way to the wheel well. However, on my car the side skirt is separated from the wheel well by the bottom of the fender.
mfarnham is offline
post #4 of 14 Old 12-29-2009, 02:36 PM
boostspike's Avatar
boostspike is more helpful than not
if you've got a WRX TR which it looks like you do, you don't really have a "side skirt" its all metal, the sti has pieces you must get out of the way to install the mud flaps just skip the step about the side skirt and continue with the install.
Nate
2006 wrx TR stg2
boostspike is offline
post #5 of 14 Old 12-29-2009, 07:40 PM
Cool, thanks for chiming in boostspike. I'd be curious to see a picture comparison between the two.
post #6 of 14 Old 12-29-2009, 11:11 PM
MurderedWRX is an unknown
i just put a set on today and it was super easy idk if you figured it out but if u go to the the links i posted it will have video for ## car on how to install them !
HSPN TV - HD Videos on Demand - Powered by HSPN Networks, LLC
if the link dont work just go to rallyarmor.com and in top right corner it will ask if your looking for install instructions and then choose ## car and go thru prompts it will show u everything u need to kno!!!! very easy very helpful!!!!
MurderedWRX is offline
post #7 of 14 Old 12-30-2009, 09:44 AM Thread Starter
mfarnham's Avatar
Thanks boostspike. I'll give it another shot.
And I'll see what I can do about some pictures, man show.
mfarnham is offline
post #8 of 14 Old 04-24-2010, 07:50 AM
PSD Operator is an unknown
I think I'm going to return mine until Rallyarmor comes out with instructions that are legible, and made for the WRX, not the STI. Since they aren't the same body, the installation instructions are incorrect. Not exactly a top quality product if they don't even provide the proper instructions...
PSD Operator is offline
post #9 of 14 Old 04-24-2010, 09:08 AM
Come on people they are mud flaps, not that hard of an install. Shit I installed mine on a wagon where I had to drill new holes because the pre drilled holes didnt line up.
nagyhead is offline
post #10 of 14 Old 04-25-2010, 11:12 AM
Keep the mudflaps and buy an STI, it's a win/win.
Ryan
2009 STi - Cobb Stage 2
VisiX is offline
post #11 of 14 Old 04-25-2010, 04:18 PM
gunk007's Avatar
gunk007 is more helpful than not
Great Idea!!
gunk007 is offline
post #12 of 14 Old 05-13-2010, 10:38 PM
NotoriousToker is an unknown
Wrong one?
Sounds to me like you just bought the one for the STI instead of the WRX. If you go to their site, the STI version appears to be different than the WRX version.
NotoriousToker is offline
post #13 of 14 Old 05-13-2010, 11:06 PM
Took me a half hour...
post #14 of 14 Old 06-04-2010, 08:59 PM
Just installed these on my wrx
Ok so I just installed the flaps on my wrx. After seeing someone in ossining with a nice custom STI with the red UL flaps, I decided to go with red instead of black. Anyway, the instructions are available via video from rally armor's website. I found, however, that on the 2010, as compared with what they call "08+", the install was not the same. First of all, in the front, there was no need to pull the liner out, it came that way from the factory. So instead, I just removed the factory clips as shown in the video, pulled the skirt back a bit as shown, and then slipped the proper plastic clips on and screwed everything in as suggested. It is not as flush as I would like it, but its fine. The rear, was a whole other story though. Unlike on the "08+" instructions, there is actually a plastic liner on the rear of the wheel well that is not on the older version. That made sighting the hole almost impossible. So I screwed in the two screws on the side, then just went straight in wit hthe screw by drilling it right through. This was not easy, there was not nearly as tall of a "lip" of vertical metal hanging down as there is in the "08+" from the video. I just pushed hard with the drill, put it on a low speed, moved my hands well out of the way, and tried about 5 times until it went through. I did a sloppy job, don't do it this way. I did not have the right tools. I suggest first lining up that last top inner hole with the plastic liner, pushing it onto the metal lip with your hand so they stay in contact, and then boring a hole by hand first through the plastic in the right spot. Then do the metal, then screw it all in. Anyway, it took longer than I anticipated. I think it would be even easier to use the "clip method" as they call it in the video, but I wanted the security of having the flaps screwed in directly. If I did it all again, I'd use the clip method. I'll post some photos, but first, how do I assign a URL to my photo? It's just a file on my computer. ?? any help there? or is there just another way to add the photo that I don't see here... new to the forum. thanks.
