Prosport Gauge Help - Subaru WRX Forum
post #1 of 3 Old 12-26-2010, 12:31 AM Thread Starter
Johnnys WRX's Avatar
Prosport Gauge Help
So i have installed my new prosport electronic boost gauge and i fallowed the directions and set my warning levels and everything but the gauge wont show any resonce at all it just bounces from negitive 10 to negitive 20 and wont move any where else then when i turn my car off and back on the gauge will blink untill i set my warning level again then i wont show anything it will just bounch around anyone please help !Cry!!Cry!
Johnnys WRX is offline
post #2 of 3 Old 12-26-2010, 07:51 PM
Hondafan's Avatar
I know this goes without saying, but I'd guess it's been tapped into the wrong signal wire. That's why it's not working properly. Check where the instructions tell you to tap and recheck what you tapped into.
Hondafan is offline
post #3 of 3 Old 12-27-2010, 12:03 PM Thread Starter
i found the problem the plug in the back was just simply was not pushed in all the way but now i have a new problem when i just turn the car on with out starting it the gauge should sit at zero and it dosent, it sits lower then zero which messes up my reading by 4 psi
