Originally Posted by 05_cgm_sti
Yes, I agree, that's the whole point of having gauges. I was just curious and wanted to know what the difference in temps would be- higher or lower?. Can anyone here confirm that 850-950c are safe numbers?
Safe numbers for what? Having your egt gauge in the d/p? The temps will be lower for sure the further away from the cylinders you are. Yes, you could technically run your egt gauge in your d/p, but that's only if you knew what your actually egt readings were that are coming out of your block and then compare them to the d/p temps. But we can't tell you the exact egt temps that are coming out of your block. If you have an egt bung in a cat-less up-pipe i'd go with that before the d/p.The closer to the cylinders the better.
