Oil PSI gauge - Subaru WRX Forum
post #1 of 2 Old 04-11-2005, 06:46 PM Thread Starter
Send a message via AIM to stvWRX
Oil PSI gauge
Hey guys
I just got my electronic Oil PSI gauge today ...
One question ... where do I tap into to make the gauge work ...
Another question doesn't the STi have an Oil PSI gauge ... if so can/where does it mount
thanks
- Steven
stvWRX is offline
post #2 of 2 Old 04-12-2005, 11:13 PM
Originally Posted by stvWRX
Hey guys
thanks
- Steven
I always use the galley plug thats underneath the IC by the PCV. You will need to remove the plug and install a new galley plug thats threaded, from here you can change the threads to standard pipe-thread and screw in your sending unit directly to it or you can screw in a crush-type pressure fitting and run a hose out to the unit.
ngeren is offline
