Go Back   WRX Forums > WRX Tech Forums > Non-Performance Tech
Old 08-15-2008, 11:16 PM   #1 (permalink)
White02's Avatar
Reputation: White02 is an unknown
Send a message via AIM to White02
Need oil pressure gauge help
So I decided I didn't wanna get rid of my car like I was planning on so I'm buying more and putting more things on the car. I just put on the oil filter sandwich plate and put in the oil pressure sending unit and oil temp sensor now the confusing part how exatly am I spoposed to conect the sending unit to the gauge all there is on the oposit side is a stud coming out of it maybe i'm missing something but I'm a little lost any help would be nice?
Old 08-19-2008, 07:27 AM   #2 (permalink)
White02's Avatar
Any one have a clue about gauges? I got them all hooked up the way the instructions told me to but they don't work. they are the cheap ebay gauges made by glow shift the lights work but the oil pressure and oil temp doesn't work so it kinda useless right now.
Anyone with any knowledge on the subject would be of a great help. Am i suposed to ground the gauge itself twice?
Old 08-19-2008, 09:56 AM   #3 (permalink)
what is your question exactly? your sender should have 2 posts coming off of it, one goes to ground, and the other goes to the input of the gauge.
Old 08-19-2008, 11:18 AM   #4 (permalink)
White02's Avatar
I actually just figured it out I got them working correctly there was only one post i guess the unit was the ground. does anyone know what is a good pressure and tempature for the vehicle to be running at when i get on it, it the pressure shoots up to close to 100.
Old 08-19-2008, 03:26 PM   #5 (permalink)
that pressure seems right. after the oil is warm and at idle mine is at 30psi, then it shoots up to 90-100 psi when i give it throttle.
my temp stays at around 180 and upwards of 200 when its really hot and i'm sitting in traffic
Old 08-19-2008, 06:44 PM   #6 (permalink)
White02's Avatar
My pressure is close to 90-100 before it warms up then after warming up it idles usually at 15 sometimes up to 25, then while driving around town low rpms its around 75ish and up to 100 on the highway. They temp stays pretty constant right around 190 - 210 weather around town or on the highway but it goes up quick to 225 sitting at a light for 10 minutes. Should I worry or is the pressure and temp fine?
Old 08-19-2008, 06:55 PM   #7 (permalink)
they are fine, yours may not be as accurate as my prosports, after all they are glowshifts from ebay.
