Go Back   WRX Forums > WRX Tech Forums > Non-Performance Tech
Old 08-27-2008, 02:59 AM   #1 (permalink)
Reputation: allstarkeep is an unknown
need a how to
so i have been looking for a tutorial for fuel pump kill switch. just need a how to for the wiring of course. i have been looking but no luck so far. i just bought a 2002 wrx sedan and am so excited and happy to have it. i just want to make sure its safe.
Old 08-27-2008, 10:31 AM   #2 (permalink)
why do you want a kill switch ? here is an ecu pinout for your car. it should help you find the fuel pump wires.
Old 08-27-2008, 11:33 AM   #3 (permalink)
I'm guessing he wants it as an anti-theft device to disable the car?
07 WRX - Cobb AP Stage 2
Online
Old 08-27-2008, 11:44 AM   #4 (permalink)
yea i want it as added safety for my car
Old 08-27-2008, 08:26 PM   #5 (permalink)
Reputation: Khooper is an unknown
An anti-theft device for a vehicle having a source of direct current ignition means and connecting means including key-operated switching means, between the said source and the said ignition means; said anti-theft device comprising a solid-state controlled rectifier having an anode, a cathode and a gate; said connecting means including first circuit means connecting the said source to the said anode through the said key operated switching means and second circuit means connecting the said cathode to the said ignition means; said anti-theft device further comprising third circuit means, including a concealed temporarily closable switch, connecting the said key operated contact to the said gate.
_________________________
Autopartswarehouse Addict!
Old 08-28-2008, 01:03 AM   #6 (permalink)
HUMANPIE's Avatar
Reputation: HUMANPIE is an unknown
Uh what?
Old 08-28-2008, 12:52 PM   #7 (permalink)
what did he just "said"?????
Old 08-28-2008, 03:05 PM   #8 (permalink)
wrxshotta's Avatar
Reputation: wrxshotta is on thin ice
that looked like it was straight copied and pasted from god knows where
Old 08-31-2008, 11:44 PM   #9 (permalink)
Car: 04 WRX
It's relatively simple. All you need is to find a wire that controls the fuel pump, for example, power. The correct way to do it is to use a relay and a switch. Then hide the switch. The ghetto way is to cut the wire and put the switch between the severed wires.
Try this link. Although it's for Hondas and Acuras, the concept is still the same.
Cause For Alarm ver6.DA - Honda / Acura Car Alarm Security - Civic, Del Sol, Integra, Prelude, CRX - version 6
RIP Colin McRae
Old 09-01-2008, 02:13 AM   #10 (permalink)
Reputation: Chase is more helpful than not
Thanks VEW, that was easier. I'm an electrician, I have to read code all the time and THAT hurt my brain to read.
I've been back and forth on doing this to my car. At the point that they've already bypassed my alarm and broken in, if the fuel pump cuts out a block away and pisses them off, I'm not sure I'd want my car back at that point.
