need advice on buffing out light scratches - Subaru WRX Forum
post #1 of 13 Old 11-01-2005, 03:54 PM Thread Starter
DEMENTED's Avatar
DEMENTED is an unknown
i have a black wrx and every single scratch is annoying me! lol
shortly after i washed the car, i found light little scratches on the trunk.
i was thinkin of buffing it out... can you recommend a good agent to use? im sketchy about using any "scratch remover" out there. i dont want to ruin the paint or cause any ugly blemishes. what materials do i need? or is this a bad idea?
i heard meguiars is good to use.
thanks in advance...
DEMENTED is offline
post #2 of 13 Old 11-01-2005, 04:06 PM
awd>fwd's Avatar
awd>fwd is an unknown
A good paste wax will conceal scratches. And it is a good idea to wax every 3-4 months anyways.
Brent
awd>fwd is offline
post #3 of 13 Old 11-01-2005, 05:04 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
If they are fine scratches then a good wax job will help. If you have a scratch's that are deeper then you will need a buffer to remove them with 3M rubbing compound with a wool wheel pad and after that step use 3M finishing glaze with a foam pad then wax. Best if done by a profesional
Ian is offline
post #4 of 13 Old 11-01-2005, 05:22 PM Thread Starter
DEMENTED's Avatar
after reading some articles, i was thinkin about using some meguiars swirl remover and then a quick waxing of the area. has anyone tried this?
DEMENTED is offline
post #5 of 13 Old 11-02-2005, 06:25 PM
WRXtreme's Avatar
I got mine professionally buffed and all the scratches that you couldn't feel if you ran your fingernail across it came out.
WRXtreme is offline
post #6 of 13 Old 11-04-2005, 11:48 AM Thread Starter
DEMENTED's Avatar
i was thinkin about doing that, but its a little more costly. plus, i dont want to have it buffed too much.
DEMENTED is offline
post #7 of 13 Old 11-04-2005, 12:38 PM
WRXforME's Avatar
WRXforME is an unknown
Bring it to Ian and have him do it
Im still looking at body kits Ian
Next spring Im gunna take a trip to New Haven and have you hook me up
About how much would it be for you to paint a front lip, side skirts, and rear bumper?
PM me if u want.
WRXforME is offline
post #8 of 13 Old 11-04-2005, 04:56 PM
Ian
Ian's Avatar
I'll do it for $350 give or take
Ian is offline
post #9 of 13 Old 11-04-2005, 07:33 PM
bigbadbuddha's Avatar
Images: 15
Megiure's stuff is good and easy to use. Problem with a black vehicle is it shows all. A good Caranuba wax does wonders.
Big Jae -
JDM version 7 bugeye
bigbadbuddha is offline
post #10 of 13 Old 11-10-2005, 11:44 PM Thread Starter
DEMENTED's Avatar
went to a shop i used to go to alot before and they'll buff it for $30. not bad huh?
id probably spend close to that much just buying the products...
DEMENTED is offline
post #11 of 13 Old 11-11-2005, 09:31 AM
WRX_JUNKI's Avatar
WRX_JUNKI is an unknown
Send a message via AIM to WRX_JUNKI
I'm going to pass by New Haven on my way to Vermont during Thanksgiving. Ian do you do paint only? HOOK ME UP~~
WRX_JUNKI is offline
post #12 of 13 Old 11-12-2005, 10:06 AM
Ian
Ian's Avatar
What do you need doing?
Ian is offline
post #13 of 13 Old 08-17-2010, 07:21 PM
baumgartenb's Avatar
baumgartenb is an unknown
With my 02 rex I just recently picked up I actually went through with 2000 grit wet sand paper (be very careful) and wet sanded the whole car lightly not to go through the clear coat, then used buffing compound and then used a finishing buffer. took the orange peel off the car as well as the little scratches. looks better then one in the show room.
baumgartenb is offline
