LED Blinker Lights (Hyperflash) - Subaru WRX Forum
post #1 of 5 Old 11-18-2010, 01:28 PM Thread Starter
Colby1321's Avatar
Colby1321 is an unknown
just put in led blinker lights in front and rear. They now hyperflash. Want it to stop but dont want to cut the stock wires and put in load resistors. Heard you can buy led heavy duty flashers, but have no idea which kind to get. Help me make the hyperflash stop, the leds look good and i dont want to take them out!
Colby1321 is offline
post #2 of 5 Old 11-18-2010, 04:15 PM
Hondafan's Avatar
Unless the LEDs have resistors already built in, you're not going to be able to fix the fast blinking without cutting wires. You can get loaded LEDs, but you'd have to look for those specifically. Load resistors aren't a big deal to install, but you also have to keep in mind that they get as hot as a regular bulb because they're taking in that additional current to slow down the blink rate. It's not a big deal to splice something in, or you could find a plug sometimes even at Autozone that would allow you to plug and play the resistors into the line without cutting the factory wires. I haven't looked for those harnesses, specifically, but I know it wouldn't be too much of a headache. PM me if you go that route and have any questions. I had to install the load resistors in my motorcycle kit when I integrated the blinkers into the taillight. Good luck!
Hondafan is offline
post #3 of 5 Old 11-19-2010, 08:58 AM Thread Starter
Colby1321's Avatar
Color-Changing LED Turn Signal Bulbs - Lighting
Found this on fastwrx. they sell a led turn signal flasher to stop the hyper-flash. Just replace your stock one with this one and the problem should be fixed. Ill try this first.
post #4 of 5 Old 11-20-2010, 04:02 PM
^ I guarantee that if I owned an 08+ Impreza, I'd have a set of those... way cooler than the chrome/amber bulbs that I currently have for my 07.
post #5 of 5 Old 11-22-2010, 10:36 AM
Those lights are sick...I agree John
