Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Non-Performance Tech
Old 06-16-2006, 10:10 AM   #1 (permalink)
Trader Rating: (3)
Lamp Replacement Guide (Osram Sylvania)
Hey guys I stumbled upon this and thought it might be of some usefulness to a few of us.. This was taken directly from www.sylvania.com
High & Low Beam Headlamp
9007
Parking Light
168
Front Turn Signal
1156
Rear Turn Signal
992
Tail Light
7443
Stop Light
7440 / 7443
High Mount Stop Light
921
Fog / Driving Light
h3-55w
License Plate
168
Back Up Light
7440
Front Side-marker
168
Rear Side-marker
168
Ash Tray
74
Map Light
168
Dome Light
DE3175
Trunk / Cargo Area
912
Old 09-17-2006, 01:33 PM   #2 (permalink)
jtodaro's Avatar
Reputation: jtodaro is an unknown
And these are for what model years?
jt
Old 09-19-2006, 04:44 PM   #3 (permalink)
jwtarbaj's Avatar
Images: 11
Reputation: jwtarbaj is more helpful than not
Also note the Wagon uses some different bulbs for the center stop light and possibly some other bulbs in back.
Old 09-25-2006, 09:53 PM   #4 (permalink)
Trader Rating: (3)
Well, since I'm running an 02 I looked them up for an 02/03.. For other models just follow the link...
Old 03-14-2007, 08:49 AM   #5 (permalink)
Reputation: raf1919 is an unknown
Send a message via AIM to raf1919
here is the 2006 WRX specs
http://wrxtuners.com/forums/showthread.php?t=12528
KN dropin w/ Velocity stack
Magnaflow catback
Old 10-10-2008, 08:59 PM   #6 (permalink)
Reputation: turmic is known to be trustworthy and helpful turmic is known to be trustworthy and helpful turmic is known to be trustworthy and helpful
This helps too. OSRAM SYLVANIA - Replacement Guide - Start
Old 02-16-2009, 05:09 AM   #7 (permalink)
Reputation: AirForce32 is an unknown
just a stupid question on this...the 06 wrx has projector headlights...yet runs a regular halogen bulb which is an H7...the 06 sti which im almost positive has the same headlights just xenon...if i want to upgrade to the xenon/hid do i just get the 9005 bulb for that said kit or go ahead and get the D2S bulb?
Stupid question, I know...just dont want to be a fool and buy the wrong thing. Thanks.
Old 02-16-2009, 12:23 PM   #8 (permalink)
No...re-read your own thought process. The 06 has a H7 bulb for low beams. So, why would you buy a 9005 kit? You'd buy a H7 hid kit. The stock projectors on a wrx are halogen projectors, not HID like the STI. So, you can't just slap D2S' in there and expect them to work. Let alone, the stock setup for the STI has a built in ballast and the correct voltage/amps to run the HIDs. The wrx won't have the correct setup to run HIDs with out the kit. BTW, the 9005 is for the highbeams on either car. You'd want a H7 hid kit, seeing as that is what you use the most. Expect it to be brighter, but to have significant glare compared to a HID projector set-up. SharpHID (a vender on this site) and other places have the kits. Just be aware that you may or may not need the battery harness for your conversion kit. My 06 didn't need it, but other people had to use it so that their HIDs work correctly.
Old 02-18-2009, 10:52 AM   #9 (permalink)
thanks for the heads up now that i re read what i posted i did pretty much answer my own question...hah. thanks.
