-   -   How do I take out my 2007 WRX's headlight? (http://www.wrxtuners.com/forums/f73/how-do-i-take-out-my-2007-wrxs-headlight-31404/)
helloimD4NNY 09-30-2011 04:19 PM
So yesterday my DRL/low beam headlight went out on my right side(luckily I didn't get pulled over) so I headed to the local autozone for a H7 bulb. My question is how do I access the dead bulb to replace it? Also is it necessary to take off the front bumper? Hopefully there's a way to change the bulb without taking the bumper off. ): Lol.
RcrsWetDream 09-30-2011 06:43 PM
1 Attachment(s)
There's an access panel on the back of the housing inside of the engine bay... Look for something that screws into the back of the headlight that's a few inches in diameter.
turmic 09-30-2011 10:19 PM
If its (right side) the passenger side...then you might find it easier to disassemble the intake to get more hand room. The whole headlight assembly doesn't have to come off to change the bulb.
man show 10-01-2011 11:16 AM
^ Agreed. Remove the intake scoop via 2 10mm bolts and you should be able to access the back of the light assembly well enough to swap the bulbs through the circular plastic screw-on cap/cover. The bulb, itself, should be held in place by a little metal clip. Be gentile with it, but it'll come apart. Use a small mirror to look at it before you mess with it if you have to.
