How do I???? - Subaru WRX Forum
post #1 of 2 Old 09-13-2004, 05:57 PM Thread Starter
How do I????
I have an 04' wagon and I would like to remove the roof rails. I noticed hex head screws underneath the rails at each end. After trying to loosen them I believe that I started to strip the heads. What size are these screws and is this the proper way to remove the rails? The screws are VERY tight.What options do I have? Thanks in advance. Peter
Druche is offline
post #2 of 2 Old 09-13-2004, 06:39 PM
Quack's Avatar
are you trying to remove the cross bars (running left to right) or the actual roof rails (running front to rear)?
the load bars are secured with a T30 TORX bolt.
here's what i used to remove the roof rails:
http://mikeegan.stormpages.com/RoofRails.html
Quack is offline
