As long as your running voltage your fine.. If your voltage drops then you will lose a little power, like 5hp, but that is normally a grounding issue as the alternator supplies the car with voltage and amperage while the engine is runing.. The battery only "Stores" the charge for large spontanious drains like a sub hit or starting the car..
