-   -   HID fogs (http://www.wrxtuners.com/forums/f73/hid-fogs-31544/)
ejs0806 10-31-2011 08:19 PM
HID fogs
Has anyone done a hid conversion for the 55w fogs?? Do you have to get the 55w hid kit or could i just run the normal 35w set up??
brfatal 10-31-2011 08:57 PM
People who run HID fogs should be thrown in prison. They neither understand exactly what the purpose of foglights is or how they work nor do they have any regard for other drivers.
ejs0806 10-31-2011 10:00 PM
First off I live in arizona so there's no fog so I don't need the actual purpose of them I have never scene fog here actually and second I live in the middle of the damn desert not near light etc... every bit of light helps as I'm pretty sure you would understand from texas ide rather not hit something. Also hid fogs are down at the ground so should bother other drivers.. only when people do fogs highs and lows and drive around with them all light up that's being disrespectful. I put hid lows in and actually adjusted my lights down a bit so I wouldn't blind other drivers. Please think a little before you need to open your mouth and be disrespectful. Also I'm here for help not to hear people talk negativily about what I want to do to MY vehicle thanks
basco 10-31-2011 10:31 PM
you obviously have no knowledge of optics at all, HID's in basically any factory Subaru housing are blinding to the oncoming traffic pretty much how ever you point them, THEY CAN NOT PROPERLY FOCUS THE LIGHT
ejs0806 10-31-2011 10:47 PM
Well I have noticed its pretty scattered I'm assuming I must have them decently pointed down I havnt been flashed yet and a little more then half my driving is done in the dark. So I don't think there that bad
brfatal 11-01-2011 08:01 AM
[quote=ejs0806;270326]Also I'm here for help not to hear people talk negativily about what I want to do to MY vehicle thanks[/quote]
AKA "only tell me what I WANT to hear". You've gotten helpful advice, but the advice you want to get is not always what you want to be told.
I'm sorry but putting HIDs in the fogs is 10 times works than putting them anywhere else. Foglights scatter a lot more than low beams by design, though with the stock bulbs they emit much lower intensity light. So no matter how low they are the light will still be in other driver's faces.
What you're looking for is driving lights.
ejs0806 11-01-2011 07:57 PM
well i dont drive around with my fog lights on regularly, only use them when im around my area which there arent many other cars whatsoever so i dont know might just leave them then
NJsupraWRX 11-01-2011 09:27 PM
i had 55w hids in all my lights.. lows, highs and fogs...
after about 6 months i took them out because i had nothing but problems. the fogs would cut out and the high beams were the worst for the car because HIDs are not meant for constant flicking on off of the lights because they need a few seconds to build up heat to fully turn to maximum. the low beams were fine. but i wouldn't recommend 55w for fogs because its such a small area and can heat up with overtime use and can melt your fog housing.
i am back to stock lights now because it was such a headache having them. and i loved the lights because i could see everything on the whole road, but i was blinding everyone.
hope this helped!
ejs0806 11-01-2011 10:49 PM
yeah thanks there a bit unreliable at times. i pieced the lows together from old ballists and buddies bulbs lol. but yeah 55w just seems like complete overkill and ive been the high route with my old truck and learned that hids dont do good on and off all the time but are nice and bright.
brfatal 11-02-2011 11:01 AM
[quote=ejs0806;270376]well i dont drive around with my fog lights on regularly, only use them when im around my area which there arent many other cars whatsoever so i dont know might just leave them then[/quote]
Like I said, you're looking for driving lights, which are long distance, higher powered hi-beams. Foglights only light up a few feet in front of the car.
Wrxsubie2008 11-03-2011 06:25 AM
Most people don't use the fogs for fog lights our cars sit how low to the ground already. The fog lights don't really do to much in the fog ( my opinion) so if we have em why not make em look good. Also I have hids as my low beams and never been flashed at or anything so the scatter cannot be horrible not to mention my cutoff is not that either.
Just my .02
brfatal 11-03-2011 10:16 AM
[quote=Wrxsubie2008;270432]Most people don't use the fogs for fog lights our cars sit how low to the ground already. [B]The fog lights don't really do to much in the fog ( my opinion) so if we have em why not make em look goo[/B]d. Also I have hids as my low beams and never been flashed at or anything so the scatter cannot be horrible not to mention my cutoff is not that either.
Just my .02[/quote]
Nice, so you're all for doing something that meets your taste in aesthetics for the car even at the expense of others. I suggest you not drive in Virginia. I have 100w driving lights that can more than return the favor. :D
basco 11-03-2011 10:41 AM
Wrxsubie2008: You don't have a bugeye so your info does not apply to us, I'm sorry your fog lights suck but our (us with bugeyes) fog lights actually do help, And don't drive in Maryland either cops will pull you over and slap you with a nice ticket for your HIDs THAT DO BLIND PEOPLE (not our fault people are too stupid to flash you)
cwinterbower 11-03-2011 10:54 AM
So much Subaru anger! HID in a fog housing is somewhat fail, both for function and for other drivers, as has been said driving lights are what you want if you want to "see the road", fogs are based on dispersing light so the reflection from the mist doesn't kill you.
Entertaining thread though, not sure where all the angst is coming from, someone must have a late drive home with some HID's coming at them every night.
basco 11-03-2011 11:30 AM
not really, I'm just sick of this topic it comes up roughly once a month and people are too stupid to research
