Go Back   WRX Forums > WRX Tech Forums > Non-Performance Tech
Old 05-20-2008, 12:14 PM   #1 (permalink)
Reputation: burtonboy759 is an unknown
Send a message via AIM to burtonboy759
hella supertone horn install question
hey guys just curious to see how anyone with the hella horns have installed them exactly. What type of wires did u have to use? (since they dont give u any and dont recommend any certain type to use)
I've read on nasioc that some people can get away with not using the relay but id rather do the install the right way. If anyone has a good place they mounted there relay let me know. I wanna get these bad boys on today cept it might rain
Old 05-20-2008, 09:09 PM   #2 (permalink)
Reputation: man show is a helpful contributing member
When I got my Supertones, I also wanted to use the relay at first, but then I looked at everything and decided it really wasn't necessary. I think I basically wired mine up the same way as the stockers, except that I fabricated my own mounting bracket and extended a wire or two so I could put the horns exactly where I wanted and then I ran a ground wire somewhere and tucked everything neatly out of sight with zip ties. I dunno if that helps at all, but it's what I did and they're fing loud. However you decide to do it, I hope you enjoy honking at other idiots as much as I do!
07 WRX - Cobb AP Stage 2
