Anyone that has these, suggestions as to where I should mount the sending units for these? I'm guessing that in the engine bay is a bad idea? Keep in mind that I live in Maine and tons of salt etc is on the roads in the winters.
I have EGT, Boost and Oil Temp. I mounted my gauges in the clock position and put the sending units inside the dash housing/defi pod housing. It's a little cramped, but it works fine.
What manual/instructions did you use to remove the clock? I am intrested in doing the same modification but need some instructions to take the dash apart.
Thanks JJS305
As soon as I can find someone with a black temp gauge in stock I'm going to be installing tbe, uppipe, and boost, egt, oil temp in a defi pod. I plan on taking as many pictures as possible and doing a how-to (hopefully not a how not-to) from a noob perspective. Should be in the next couple weeks at the most if you can wait that long.
I just installed a fuel temp guage, pryometer and boost guage in a three guage mount a-pillar, it looks pretty good, now all I need to find is to find a manuel with the proper settings, any suggestions where I might find that??
I guess I didn't word it correctlly, I'm pretty new at this, I guess what I meant, what is the proper temp to watch for on the pryo, where would I find figures like that. Thanks Cosmo, your dealing with a newbie
Cosmo
I think I asked a reasonable question and expect a reasonable answer. If you cannot answer the question maybe someone else can. As modarator you should act more mature.
jjs305
Man its not hard, you pry up the plastic and then remove a few screws. His answer wasn't immature
