Gauge Pods - Page 2 - Subaru WRX Forum
post #16 of 30 Old 02-17-2004, 11:26 PM
avatarr is an unknown
I would recommend the derres catalano gauge mask with modified OEM pod. It looks very smooth, not too overpowering, and fits 52mm pods.
-Jason
-Jason
"Horsepower sells cars, Torque wins races." -Unknown
avatarr is offline
post #17 of 30 Old 02-17-2004, 11:26 PM
I had one for my '02 wrx. I'll see if I can dig up a picture.
-Jason
-Jason
avatarr is offline
post #18 of 30 Old 02-17-2004, 11:31 PM
Here it is:
-Jason
avatarr is offline
post #19 of 30 Old 02-17-2004, 11:41 PM
Maulzar is an unknown
Send a message via AIM to Maulzar
avatar did you install those pods yourself or did someone do them for you? If you installed them how hard was it? Do you think you could help me out in installing mine when i get them? Also what is that one in the middle EGT?
Maulzar is offline
post #20 of 30 Old 02-17-2004, 11:47 PM
i did install it myself. very simple. i wouldn't mind at all helping you. and yes, the one in the middle is the EGT AKA pyrometer.
-Jason
-Jason
avatarr is offline
post #21 of 30 Old 02-17-2004, 11:48 PM
I do plan on getting the same pod for my STi. Functional and very svelte.
-Jason
-Jason
avatarr is offline
post #22 of 30 Old 02-18-2004, 02:28 AM
Are those gauges all by autometer? and i have heard problems with the autometer EGT gauge did you have any problems at all
Maulzar is offline
post #23 of 30 Old 02-18-2004, 07:43 AM
they are and i never had a problem with any of them. *shrug*
-Jason
-Jason
avatarr is offline
post #24 of 30 Old 02-19-2004, 12:39 AM
ok one more thing re they electronic of mechanical
Maulzar is offline
post #25 of 30 Old 02-19-2004, 06:44 AM
WRXblurr's Avatar
WRXblurr is an unknown
By the pic i would think they are the cobalt series.. wich are all electronic..
WRXblurr is offline
post #26 of 30 Old 02-19-2004, 07:07 AM
they are the sport comp series IIRC. the boost gauge is mechanical. the a/f and egt are both electronic but all a/f and egt gauges are electronic.
-Jason
-Jason
avatarr is offline
post #27 of 30 Old 02-19-2004, 05:27 PM
BlueDemon's Avatar
BlueDemon is known to be trustworthy and helpful BlueDemon is known to be trustworthy and helpful
The problems you've heard about are with the sensor, which is pretty long and prone to breaking apart and doing damage to your engine's vitals. I believe there are replacement probes which are shorter though.
Blue
BlueDemon is offline
post #28 of 30 Old 03-07-2004, 02:22 PM
iareben is an unknown
If i was to get three gauges which ones do you think I should get? I was thinking A/F Ratio, EGT, and Fuel Temp. I dont need a boost gauge because I'm getting a dual turbo timer. Or do you still think I need one?
iareben is offline
post #29 of 30 Old 03-07-2004, 05:07 PM
BlueDemon's Avatar
This topic has been covered 10 fold. But out of the kindness of my heart, I'll tell you my Opinion of which three gauges you should get:
EGT, Boost, Oil Pressure/ or Temp.
No real need for A/F gauge, unless you plan on buying a Wide Band O2 sensor, then it's a good purchase (otherwise it's just a purty light display that won't tell you jack). Fuel Temp is basically useless unless you're SUPER MODIFIED.
I personally feel a Good Boost gauge is necessary, regardless of whether you are getting a dual turbo timer... that way, you have two points of reference. Also, who's to say that dual turbo timer is completely accurate?
Oil Pressure or Temp is very important because Oil is the life blood of your vehicle.
And we all know why an EGT gauge is so important.
Blue
post #30 of 30 Old 03-07-2004, 07:15 PM
i would say oil pressure is more important than oil temp should you have to decide between the two. this is quite common since the majority of the pods that go where the clock is right now hold 3 gauges. boost and egt are pretty much givens. then you have to decide on one more. :shrug:
-Jason
-Jason
avatarr is offline
