Fog light mod on 08+?? - Subaru WRX Forum
post #1 of 1 Old 08-31-2009, 12:46 PM Thread Starter
Send a message via AIM to Mustang
So I tried following the instructions here and no matter which wire I remove from the fuse block, with the jumper in place in an empty fuse spot my headlights are always on. Any thoughts as to what step I'm missing?
I ran a jumper from the VY wire on the turn signal stalk harness, to the upper right terminal on the fog light relay... Then ran another jumper from the lower right terminal on the relay to an empty spot on the front of the fuse box. I can't figure this out...
Mustang is offline
