DVD player e brake wire - Subaru WRX Forum
post #1 of 8 Old 12-24-2007, 04:06 PM Thread Starter
xmoniewrx's Avatar
xmoniewrx is an unknown
Ok I ran and did not find it. I got a flip out dvd player it is all working the way I install it. What I was wondering if anyone knew where to hook the wire so that the dvd plays when you are driving. I know it is illegal it most states but am aware if the risk of tickets I had it hooked up in my other car for four years but I can not find a spot on this car.
Thanks in advance!
xmoniewrx is offline
post #2 of 8 Old 12-24-2007, 04:15 PM
C-Mo's05Rex's Avatar
C-Mo's05Rex is an unknown
you have to attach the brake wire to any ground
C-Mo's05Rex is offline
post #3 of 8 Old 12-24-2007, 04:45 PM Thread Starter
xmoniewrx's Avatar
an active ground wire?
because I have tried a ground and it does not work.
post #4 of 8 Old 12-24-2007, 04:56 PM Thread Starter
xmoniewrx's Avatar
Ihave tried an active ground and active ground wire.
post #5 of 8 Old 12-24-2007, 06:33 PM Thread Starter
xmoniewrx's Avatar
okay i got it working while it drives I don't know why it wasn't working before maybe bad connection on my part. Anyways C-Mo's05REX was right it needed to be grounded and for some reason I messed it up but anyways here is a pic where I grounded it, hopefully it will help some day. I grounded on the ebrake inbetween two 10mm bolts which is where i grounded it the last time in my eclipse so I can say it has been a success in at least two cars.
post #6 of 8 Old 12-24-2007, 07:33 PM Thread Starter
xmoniewrx's Avatar
nevermind it reset it self and it is not working now. get back to guys going to try something new.
post #7 of 8 Old 12-24-2007, 09:07 PM
joechatham69 is an unknown
it depends on what dvd unit u have. pioneer, ecslipse, alpine? if its a newer model pioneer ure screwed ### they have gyros in them so if u roll over 25mph the picture cuts off. if its an older model depending on which one it is (pioneer) u have to either add a wire to the harness going to the unit or hook up a toggle switch. it all depends on which unit u have
joechatham69 is offline
post #8 of 8 Old 12-25-2007, 12:08 PM Thread Starter
xmoniewrx's Avatar
Okay I got it LOL well I left the parking wire as is, but that wasn't the problem the reason I couldn't get a screen is that I hooked up my reverse light/rear camera line which I do not need to hook up because I have not installed a camera. It was interferring with the screen by overriding into rear camera mode evertime I turned It on. Once I cut it though it gave me the warning screen again but I did find an override technique to disable the watch by drive function for a Dual XDVD8181.
Effective Dual DVD Bypass Codes w/ NO SWITCH
I know what everyone is going to say DUAL is junk but i had one in my other car for three years with no problems and you cant beat the price. Anyways it looks great and I am happy FINALLY! Thanks for all the help.
