Go Back   WRX Forums > WRX Tech Forums > Non-Performance Tech
Old 04-28-2004, 04:24 PM   #1 (permalink)
IBAUCLAPlaya's Avatar
Car: 04 WRX
Trader Rating: (1)
Defi Gauges
I am thinking of ordering the Defi V2 Link gauges from www.edoperformance.com. I have a few questions first.
1. How hard is it to link the 3 gauges that are placed in center of dashboard where stock clock was to Control unit between driver seat and handbrake?
2. How hard is it to install the EGT and Oil Temp sensor?
3. Where exactly should I put the EGT sensor, I am going to have a full turboback exhaust, uppipe and TXS TMIC?
4. How hard is it to install the boost gauge?
5. Do the gauges all come w/ installation instructions?
6. Does anybody know a place to buy a cheap Defi gauge hood for under 150?
7. What paint should I use to try and match stock dash?
I am a kid as you guys all know that is 16 and w/ not many tools. I removed my intake silencer and installed a HKS SSQV and removed my IC pretty easily. Can I do all this with simple tools and not much experience?
Old 04-28-2004, 06:39 PM   #2 (permalink)
awdturbo04's Avatar
Car: 04 WRX
Reputation: awdturbo04 is an unknown
1. To link 3 gauges it takes all of 3 seconds and putting the control unit inbetween the seat what i did is i made a fiberglass box for it. I guess you could like stickey tape it or somthin. Or I could sell you a box if you wanted.
2. The egt sensor was easy to do. Basically it is like drilling somthin the hard part was removing that part of the exhaust mani. This really wasent all that hard. If the oil temp sensor is the same way you should be fine.
3. I think you put it 3 inches from clyinder number 3 which is the one closest to the passanger. Im not positive though do a search. Thats where I put it.
4.The boost gauge is like this cut hose stick in T connect hose done. I put it on the line that goes to the bov and it seems to work fine.
5.Yes they all come with installation instructions but they only help if you can read japanese. If not go to there website and download them.
6. I do not know
7. I think that they already come painted.
I installed mine by my self and 2 defi's of my friends and I am 15. You should do fine
Old 04-28-2004, 07:52 PM   #3 (permalink)
Car: 04 WRX
Trader Rating: (1)
So I have to drill into exhaust manifold!? Do I need to thread the hole? Ahh I don't know if I want to put a hole in my manifold.
Also from question 1 how did u run the wires from between driver seat and handbrake to the clock?
Old 04-28-2004, 08:09 PM   #4 (permalink)
T WREX's Avatar
Reputation: T WREX is an unknown
Send a message via AIM to T WREX Send a message via Yahoo to T WREX
you can buy a sandwich adapter that goes between your oil filter and block for the oil temp sensor, this is gonna be like another $100 from what I've seen.. and also I just saw a defi pod over on nasioc for $110 painted black to match, but stuff sells quick over there so who knows if it'll be available still.
FP Green'd 04 STi
Trevor
Old 04-28-2004, 08:39 PM   #5 (permalink)
awdturbo04's Avatar
Car: 04 WRX
The holder I mad had a hole going out the side that lined up tp s;ide right under the center counsoul
Old 04-28-2004, 08:59 PM   #6 (permalink)
Car: 04 WRX
Trader Rating: (1)
Damn, I think I am going to put my control unit closer to the steering wheel.
DOES ANYBODY KNOW OF ANY PEOPLE/SHOPS AROUND THE CLEVELAND AREA THAT IS EXPERIENCED W/ WRX'S?
Old 09-22-2005, 04:10 PM   #7 (permalink)
o5WRX's Avatar
Car: 05 WRX
Reputation: o5WRX is an unknown
Where did you end up placing the oil temp sensor? The people installing my Defi gauges said I need a block that goes between the oil filter and motor to place the sensor in. I was wonderin if it would fit in the drain plug? They say it may not fit in the drain plug... If I need the adapter block where will I be able to find it?
Old 09-22-2005, 11:37 PM   #8 (permalink)
BlueDemon's Avatar
Reputation: BlueDemon is known to be trustworthy and helpful BlueDemon is known to be trustworthy and helpful
They sell Drain plug adaptors for oil temp sensors. I personally went with Greddy's Oil Filter Sandwich Adapter. Check Greddy's website for details and pricing, it has two ports, so you could even do oil pressure if you wanted.
I went with the Driverside exhaust manifold, and drilled the casting button. It has enough thickness so that it's very easy to tap the hole. After that, it's all down hill and VERY simple. My EGT sensor is still functioning perfectly after more than 2 1/2 years.
If the boost gauge is anything like Greddys, then it's a simple process of T'ing off your boost gauges vacuum line and running the sensor to that, and then the sensors wiring to the gauge.
Blue
Old 09-23-2005, 02:44 AM   #9 (permalink)
T WREX's Avatar
You do not have to spend the money for a sandwich adapter of any kind, or a drain plug adapter. You can get Subaru part #: 11024AA210 . This replaces a plug on the top of the block under the intercooler, passenger side of the block. It's like $3-$5, and your temp probe should thread right in.
Stock plug:
Location of stock plug:
Factory replacement part:
More pics of location:
Good luck!
-Trevor
FP Green'd 04 STi
Trevor
Old 09-23-2005, 10:01 AM   #10 (permalink)
BlueDemon's Avatar
That's a great find, though that location is suited more for an oil pressure probe (both types would work, but I'd prefer to put an oil pressure in that location; more accurate).
Blue
Old 09-23-2005, 10:09 AM   #11 (permalink)
insanity500's Avatar
Car: 05 WRX
Reputation: insanity500 is an unknown
Send a message via AIM to insanity500
T-WREX, are there supposed to be pictures in your post? If so I am unable to see them (Could be just me though)
Old 09-23-2005, 10:49 AM   #12 (permalink)
T WREX's Avatar
Blue
There is actually an identical plug in the front of the engine just behind the alternator (that's what this p/n actually is) that is used for the oil pressure dummy light.
I swiped the pics off Nasioc and Scoobymods...not sure if they're working for everyone or not.
FP Green'd 04 STi
Trevor
Old 09-23-2005, 04:10 PM   #13 (permalink)
Car: 04 WRX
Trader Rating: (1)
I have that plug from a while ago, brand new that I haven't used. Let me know if you want it...
Old 05-21-2007, 10:01 AM   #14 (permalink)
Reputation: nagyhead is known to be trustworthy and helpful nagyhead is known to be trustworthy and helpful nagyhead is known to be trustworthy and helpful
I know this is an old thread but, I bought this part from subaru to install a Prosport oil pressure guage, The threads are different so the oil pressure sensor dose not thread into it. and it cost 14 dollars.
where else can I install it, or dose anyone know where i can get an adapter?
Old 05-21-2007, 11:30 AM   #15 (permalink)
Reputation: newtothegame is a helpful contributing member
Check out JSCspeed.com. They have an oil galley plug that is supposed to work well and I believe it only costs like $9. I think that is what you are looking for correct?
