Ddm HIDs - Subaru WRX Forum
 3Likes
  • 1 Post By turmic
  • 1 Post By BLAZE2099
  • 1 Post By brfatal
post #1 of 13 Old 12-03-2013, 07:35 PM Thread Starter
Subieblue03's Avatar
Subieblue03 is an unknown
Ddm HIDs
I just bought some ddmtuning HIDs and they won't work I can't get them to come on at all is there a special kit you have to buy I know on certain years of dodge cummins you have to have a certain kit
Sent from AutoGuide.com App
Subieblue03 is offline
post #2 of 13 Old 12-03-2013, 07:47 PM
Don't use them anyways...HIDs need a retrofit or a HID headlight assembly that is OEM.
post #3 of 13 Old 12-03-2013, 08:02 PM
Premium Member
Nathan21's Avatar
Nathan21 is an unknown
Kirt, is a retro fit as bright as an HID, or is a retro fit have an HID in them
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #4 of 13 Old 12-03-2013, 08:14 PM
A retro fit is fitting HID projectors in a non-HID headlight. It can sometimes be even more clear than some OEM headlights because certain projectors are better than others.
Nathan21 likes this.
post #5 of 13 Old 12-03-2013, 08:17 PM
You need to either have them retro fitted or buy a used set of JDM headlights, which look way better IMHO.
That may be biased though
turmic likes this.
post #6 of 13 Old 12-03-2013, 08:43 PM Thread Starter
Ok thanks for the info I'll put the ones I bought in my girlfriend mustang lol
post #7 of 13 Old 12-04-2013, 12:00 AM
n8mcd is a helpful contributing member
I had to wire up my hids using a relay off of the stock plugs because just plugging them in didn't work for me either. You just use the stock plug to activate a relay and run a power wire from the battery (fused of course) through the relay to the hid positive, then run the hid ground wire to the chassis, boom the lights work with the stock switch and you don't have to worry about melting the stock harness or cutting into anything.
n8mcd is offline
post #8 of 13 Old 12-04-2013, 07:31 AM
This isn't much better. Any car that doesn't have HID optics shouldn't run HIDs at all. She needs a retrofit as well. Bugeyes are just known to be extra terrible with the wrong type of lights put in.
BLAZE2099 likes this.
post #9 of 13 Old 12-04-2013, 10:11 AM
Haw1es's Avatar
Haw1es is more helpful than not
So, somewhat of a thread jack, but I have HIDs in mine and I'm not sure that the housings were replaced when they were done. So I have 2 easy questions, 1 how do I tell if they have been changed and 2 if they have not been replaced how hard is it to go back? Ie do I just unplug the ballasts and put non HIDs in?
Shane
2010 WRX
2014 F150
Haw1es is offline
post #10 of 13 Old 12-04-2013, 11:40 AM
Take a picture of the housings with the lights off and post it here, and yes you can just go back to standard bulbs as long as whoever installed the kit didn't cut or mess with any wiring.
n8mcd is offline
post #11 of 13 Old 12-04-2013, 02:34 PM
Haw1es's Avatar
^ will do tonight, I'll start my own thread. Thanks!
Shane
2010 WRX
2014 F150
Haw1es is offline
post #12 of 13 Old 12-04-2013, 05:10 PM
99 in 100 people just toss HIDs in. I doubt you have retrofits.
post #13 of 13 Old 12-04-2013, 06:51 PM
Is your car a limited?
