Cleared Headlights Question - Subaru WRX Forum
post #1 of 8 Old 07-06-2005, 01:44 PM Thread Starter
HumP is more helpful than not
Send a message via Yahoo to HumP
Exclamation Cleared Headlights Question
I've helped my friend clear his headlights using the oven technique, but I was wondering if it can be done with a Heat gun?
HumP is offline
post #2 of 8 Old 07-07-2005, 01:15 AM
It would seem easier doing it in an over in my head since it's evenly heated all around. A heat gun would take some time, and doesn't gaurentee you won't miss a spot and give you trouble when you try to take it apart... or put it back together for that matter. 200 deg f at 10 minutes is a lot!
post #3 of 8 Old 07-08-2005, 01:19 AM
cannibal86 is an unknown
Do it in the oven - safer and easier. Heat gun, if not used properly might even melt some of the plastic.
cannibal86 is offline
post #4 of 8 Old 08-17-2005, 04:52 PM
silver02wrx's Avatar
silver02wrx is an unknown
i cleared my headlights by breaking the orange inside then getting the pieces out. It was a bitttch. I tried the hairdryer and it was also very hard and risky.
silver02wrx is offline
post #5 of 8 Old 08-18-2005, 02:25 AM
... you don't have to break anything. The turn signal is unscrewed out while the parking and side marker is "unclipped" out. Your life would have been much easier using an oven and some oven mits.
post #6 of 8 Old 08-18-2005, 11:14 AM
Jave's Avatar
Jave is more helpful than not
exactly the way I did it. Easier than I though t it would be.
Jave is offline
post #7 of 8 Old 08-18-2005, 12:28 PM
Nose Nuggets's Avatar
what are you guys talkin about? what are you clearing out of the headlights?
oohhh is this an 04 05 thing? to get the orange out?
Nose Nuggets is offline
post #8 of 8 Old 08-18-2005, 11:43 PM
Yes, these's also a similar mod for the 02-03's however. Check scoobymods
