cd player help - Subaru WRX Forum
post #1 of 3 Old 05-16-2004, 06:44 PM Thread Starter
cd player help
how do you get the cd player out of the councel with out breaking anything?
T-WRX32 is offline
post #2 of 3 Old 05-16-2004, 06:57 PM
Tut4u2's Avatar
Images: 11
Open up the cup holder. Take out the two screws on either side of it, which hold it in. Then pull it out. Then put your hand around that silver trim and pop each one out nice and slow (might seem you will break something but you won't). Then there are three screws on either side of the HU which hold it to the chasis. The two lower ones are a ##### to get out if they fall so be careful. There is a 14 pin plug on the back of the HU, the Antenna line, and the ground, which you push down and back on to get out. Also if you have the factory sub, then there is another ground which is screwed onto the HU.
Che
Tut4u2 is offline
post #3 of 3 Old 05-16-2004, 09:46 PM
jwtarbaj's Avatar
Images: 11
Look on scoobymods.com
They have a great write up on stereo removal with pictures!
jwtarbaj is offline
