Boost pressures? - Page 2 - Subaru WRX Forum
post #16 of 25 Old 03-02-2012, 09:43 AM
Do you have a CEL or is your cruise light on? You could be in limp mode.
post #17 of 25 Old 03-02-2012, 01:37 PM Thread Starter
Duffie112 is an unknown
No lights on. Here are MY pics just took them
Duffie112 is offline
post #18 of 25 Old 03-02-2012, 07:57 PM
bad grocerygetter's Avatar
I wouldn't guess that its too small...not a big fan of the clear hose but it should be ok.
Kevin.
bad grocerygetter is offline
post #19 of 25 Old 03-02-2012, 08:25 PM Thread Starter
The clear hose came with the boost gauge . And I've seen it move more just used to my diesel pickup making 40 lbs lol
Sent from my Autoguide iPad app
post #20 of 25 Old 03-02-2012, 08:28 PM
Replace the clear line with actual fuel line (helps with heat and crimping) Some may not agree.
Did you get an OBD to read a CEL ? Or an AP ?
post #21 of 25 Old 03-02-2012, 09:23 PM Thread Starter
No didn't read any codes. No lights are on the dash
post #22 of 25 Old 03-02-2012, 10:26 PM
The ECU stores codes FYI
post #23 of 25 Old 03-02-2012, 10:57 PM
Is it just me or is his T connection ass backwards? Well 90* off...or will that not matter?
post #24 of 25 Old 03-02-2012, 11:13 PM
Won't matter, still reads pressure
post #25 of 25 Old 03-03-2012, 06:41 PM
Lack of sleep makes me say dumb things....
Well...the only thing question is. Does it move above 6 psi when you're at WOT in 3rd gear? If you reach redline and it never climbs higher than 6 psi, but you're feeling the boost. Then your hose or the guage is faulty. Unless you're car has some serious boost issues it should easily boost over 6 psi.
