Boost gauge vacuum hose - Subaru WRX Forum
post #1 of 2 Old 03-08-2004, 03:28 PM Thread Starter
Narrus's Avatar
Send a message via Yahoo to Narrus
After looking a bit, I keep reading about people using 1/4" vacuum hose to install a boost gauge. Is it not recommended to use the nylon hose that comes with the kit? Will I get better readings from the 1/4"? Plus I was planning on running mine through the engine compartment to the plug under the driver's side dash. Is this not wise?
Narrus is offline
post #2 of 2 Old 03-08-2004, 07:24 PM
zoinks's Avatar
Send a message via AIM to zoinks
I definitely scrapped the nylon piece of crap that came with mine along with the crush fittings. Instead I used 1/8" black vacuum hose. I made a brass tee with barb fittings to tap into the line and put an 1/8" barb on the back of the boost gauge. It is instantly responsive and much better than the supplied line.
zoinks is offline
