Boost gauge - Subaru WRX Forum
post #1 of 8 Old 06-17-2009, 12:29 PM Thread Starter
Danielson's Avatar
Danielson is an unknown
Boost gauge
hay guys just got a Prosport Premium boost gauge and I love it all but the fact that it does not read above 0 it sits at -20psi and as I give it gas it gos up to -10psi then -2psi and by then I need to shift I checked all the wires for a loose connection and the Tubing for a leak but they are all good I'm at a loss on what to do?
I taped into the line coming off the BPV to go to the sensor
and Wired it in through the clock
2005 WRX
Borla XR-1 CBE Best Purchase so far
"Wax on wax off"
Danielson is offline
post #2 of 8 Old 06-17-2009, 02:45 PM
Is it the mechincal or electrical gauge?
post #3 of 8 Old 06-17-2009, 03:10 PM Thread Starter
Danielson's Avatar
oh yeah forgot it Electical and just talked to prosport and they asked a bunch of Qs and told me I should not wire it in through the clock where you guys wire it in?
2005 WRX
"Wax on wax off"
post #4 of 8 Old 06-17-2009, 03:12 PM
fuse block...tapped into the radio fuse and the light fuse
post #5 of 8 Old 06-17-2009, 03:37 PM Thread Starter
Danielson's Avatar
How????? did you just shove the wire in with the fuse???????
2005 WRX
"Wax on wax off"
post #6 of 8 Old 06-17-2009, 03:41 PM
Fuse Taps (4-Pack) - RadioShack.com
and then just attach the appropriate spade connector to the wire
post #7 of 8 Old 06-17-2009, 03:42 PM
you could just shove the wire into the fuse but it looks like crap and causes major electrical risks
post #8 of 8 Old 06-17-2009, 07:04 PM
boo-key's Avatar
I used a adapter that makes one fuse spot into two! I got it at auto zone.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
