Blitz turbo timer/boost gauge question? - Subaru WRX Forum
post #1 of 2 Old 02-14-2005, 06:20 PM Thread Starter
Ian
Ian's Avatar
Send a message via AIM to Ian
Ok, so I have everything installed and working fine, but I'm not sure if the boost gauge is hooked up in the right place or am I just not used to a Kpa reading instead of PSI, is Kpa the same as a bars pressure reading? So can someone tell me where I am supoesed to splice it in and pics would be great too! if you can.
Thanks, Ian
Ian is offline
post #2 of 2 Old 02-15-2005, 07:18 PM
IBAUCLAPlaya's Avatar
KPa is the same as bar. Splice the boost line it? You should do it about 4-5 inches off the bypass valve.
IBAUCLAPlaya is offline
