Originally Posted by ajmilano
I have a valentine one, and it has saved me a ridiculous amount of times. I have it mounted right above the rear view mirror. It says in the manual u want it as high as u can to give it the furthest line of sight. And it has given me laser alerts from hiding cops plenty of times, and it also seems that if i mounted it lower the rear sensors on the V1 would be useless.
Call me out all you want but both these points are exactly correct. I also have mine just below the rear view mirror. I have never had a problem. I get Laser warnings just fine. I pass a State trooper in the center divide nearly daily and it always goes off (Laser warning) as I crest the hill.
Direct from V1 Manual available here ->
http://www.valentine1.com/moreinfo/V1_Owners_Manual.pdf
Valentine One works best when mounted high in the
windshield, and toward the center between the windshield
pillars. Use your choice of windshield or visor mounts.
• When properly mounted, the front antenna will look
forward through the glass. It must have an unobstructed
view. Don’t put it behind the parked windshield wipers,
or directly behind an in-glass antenna. Don’t position it
so that it "looks" into the rearview mirror.
• The rear antenna will look rearward, between
passengers and out the rear glass. It, too, must have an
unobstructed view.
• Detector performance is enhanced by a high mounting
position. Two reasons. For radar, a longer sight line to
the horizon always helps. For laser, moving away from
the hood and its sun reflections helps a lot.
