Audio Set Up: 07 WRX - Page 2 - Subaru WRX Forum
post #16 of 18 Old 12-28-2011, 03:00 PM Thread Starter
BoostinChick is a helpful contributing member
I will look into it and see where others are mounting theirs. I don't want to hack up the car too much just in case I want to throw everything back to stock. Also, if I go to the track (tech inspection), I would have to figure out the whole kill switch deal.
- Sandra
2007 WRX TR | Stage 2 | PAR Gearset (Built by AndrewTech)
BoostinChick is offline
post #17 of 18 Old 12-29-2011, 09:06 AM
Grounding/making new ground to the chassis I would not consider hacking up the car. Where I worked, everything we did, had to be of professional quality and also be able to revert the car back in case the owners decided to sell the car. Making grounds and removing them later was acceptable practice. The seat belt mount option would leave little trace other than some scuffed up paint under the seats. What I'm trying to say, if you take this out somewhere, they're going to do the same thing if not worse.
Yes, for tracking the car, you'd have to have an external battery kill switch outside of the vehicle if you moved the battery. Not worth it IMO if this is a daily driver that you don't track often or if you plan on reselling the car.
post #18 of 18 Old 12-29-2011, 10:06 AM Thread Starter
I was referring to the battery relocation as the "hacking" I understand that for the grounds I will need to scratch up some paint. Not too worried with that.
- Sandra
