Which wires do you cut or whatever to make it so I can arm the alarm while the car is running down? I read a thread, but I can't find it anyway. Any information would help. Thanks.
You can't arm the alarm, if you do while the car is running, the motion sensor will go off. You can however lock the doors, by cutting the dark green wire w/ a black stripe in the keyless entry module which is under the dash right on top of the fuse box. Then you cut the grey wire in the security module box which is located in the center console right under the mirror adjustment button and by the ebrake.
