I just purchased an apexi turbo timer and first off I have heard that the blitz harness will work with the apexi in an 02, I just wanted to confirm that this is correct. Second I would like to know what the wire color of the o2 sensor wire is coming from the ecu. I am aware that it will not give a completly accurate reading but i would like to get it hooked up so it is at least reading something. The pin postion will also work but i would really like to know the wire color.
Thank You
Thank You
