wondering how u guys mount your ap (i have version 2 in a bugeye) without getting that long wire in the way. is there a shorter wire and mounting bracket i can buy?
Not a bug eye but I have mine mounted to the stereo surround with the cable wrapped up into a loom. The OBD2 port is mounted to a piece of alluminium that I bent forward to keep the cable from hanging too low.
I mounted it on the valence between the centre vent and stereo, and when the double-sided adhesive failed I drilled through the valence and used small discrete screws to fasten it neatly. Now I have holes though.
We routed the OBD-2 wire permanently under the dash and just below the ashtray opening, and used nylon ties to fasten the surplus out of the way under the dash.
It was a very clean install, that I was happy with.
