Amp rated higher thAn subs? - Subaru WRX Forum
post #1 of 12 Old 11-02-2013, 02:53 PM Thread Starter
n8mcd is a helpful contributing member
I'm not really into car audio but I came across a pretty good deal on some pioneers and an amp and installed them today (with help). The amp is 800w peak and 350w RMS and the subs are only rated at 150RMS... I want to know how to safely adjust the gain to get the max output from the subs without hurting them... We had the gain on the amp turned up half way and it sounded amazing but my friend said that it was too much so we turned them down...
Basically I wanna know how one would go about getting the right gain to the subs without burning them up, since the amp can put out more than twice the power that the subs are rated at...
Thanks
Nate
n8mcd is offline
post #2 of 12 Old 11-02-2013, 03:00 PM
Premium Member
Nathan21's Avatar
Nathan21 is an unknown
Alright to get a perfect adjustment you would need a special tool to read the right amps, to also to mind you, you amp with put at different rates has you RPMs on your car goes up n down, to takes a good ear to adjust it right but there is really no "perfect" balance to where you can set it
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #3 of 12 Old 11-02-2013, 03:07 PM Thread Starter
I know there are special tools for this job but I am sure most people dont have that tool... basically how would you adjust it? I dont wanna blow the subs... how do i tell if im overworkig them? my freind said he smelled it getting too hot but i didnt smell it until my head was right in the sub... is there a way to use a standard multimeter to figure out wattage?
n8mcd is offline
post #4 of 12 Old 11-02-2013, 03:10 PM
Premium Member
Nathan21's Avatar
Yeah but also every sub is different, can you give me more information on the amp and subs
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #5 of 12 Old 11-02-2013, 03:13 PM Thread Starter
pioneer 6m-7300m amp 800 watt max 350w rms
2 pioneer ts-w301r 800w max 150w rms subs
subs are 4ohm if that matters
thank you for the quick replys
n8mcd is offline
post #6 of 12 Old 11-16-2013, 04:37 PM
jjohn390 is an unknown
If you have (2) 150W subs wired in parallel then the total power the subs can handle is 300W @ 2 ohms. The amplifier is rated at 360W @ 2 ohms. You can have it turned up to 75% and still be safe. The subs will begin to distort and bottom out before you burn them out.
jjohn390 is offline
post #7 of 12 Old 11-16-2013, 07:31 PM
Premium Member
Nathan21's Avatar
Depends on how old the subs and amp is, newer amps have built in fail safes to where the sub will send a little signal back before it blows and the amp will lower the power to it! I've ran two JL 12W6 off of a 1000/1 amp and those subs were really old but since the amp was newer it wouldn't blow the subs, and trust me! I TRIED haha and tried for 6 months till I gave up!
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #8 of 12 Old 11-16-2013, 09:33 PM Thread Starter
I think that mine might be that way because I have it turned up pretty far and it hits really hard for a minute or so then it doesn't hit as hard
n8mcd is offline
post #9 of 12 Old 11-17-2013, 09:51 AM
Premium Member
Nathan21's Avatar
Look for small rips or rates in the foam around your sub
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #10 of 12 Old 11-17-2013, 01:14 PM Thread Starter
I don't see any, they sound good it just seems like when I first turn them on they hit harder then after a few minutes they back off to a normal level
n8mcd is offline
post #11 of 12 Old 11-17-2013, 01:45 PM
Premium Member
arewmors's Avatar
Maybe because they're cold and stiffer, then warm up become more flexible?
Andy - 12 WRB WRX
Tuned by Innovative Tuning
294 AWHP / 311 TQ
arewmors is offline
post #12 of 12 Old 11-17-2013, 05:03 PM Thread Starter
^ could be, I don't know much about sound systs
n8mcd is offline
