Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Non-Performance Tech
Old 07-28-2009, 07:39 PM   #1 (permalink)
Reputation: dmcutter is an unknown
Alarm sounding when using door key
Today the battery in my remote apparently died and when I opened the door with the key, the alarm went off. This also happened a couple of weeks ago, the only other time I've used the key instead of the remote. I found nothing in the manual about what would cause this. Any ideas?
Thanks
Old 07-29-2009, 09:11 AM   #2 (permalink)
Reputation: VisiX is a helpful contributing member
Manually unlocking my doors has always set my alarm off, I guess I just assumed that is how it works. If you start the car the alarm should stop.
Old 07-29-2009, 09:19 AM   #3 (permalink)
Club Region: Southeast
Reputation: basco is known to be trustworthy and helpful basco is known to be trustworthy and helpful
yeah it tells you in the manual that if you un-lock the car with out the keyfob that the alarm will sound unless you lock all of the doors manually because then the alarm doesn't arm itself
Proud Pilot of FP Green powered Grocery Getter and Stage II Evo VII daily driver
BaScO aka Matt
Old 07-29-2009, 12:18 PM   #4 (permalink)
Okay, thanks. Seems strange it would work that way, but I guess it's just a good reason to keep fresh batteries in the remote.
Old 07-29-2009, 12:33 PM   #5 (permalink)
it does it so that if someone tries to pick your lock the alarm will sound
BaScO aka Matt
Old 08-02-2009, 12:48 AM   #6 (permalink)
Stevo198's Avatar
Car: 09 WRX
Reputation: Stevo198 is an unknown
The secret is you have to turn the key to the unlock side three times to disable the alarm. Thats how it is on my 3g wrx anyways
