3G 5 door Signal/Reverse lights - Subaru WRX Forum
post #1 of 1 Old 05-13-2011, 04:42 PM Thread Starter
jonathang's Avatar
jonathang is an unknown
I don't like the fact that the hatch portion of the rear light (the reverse light) is used so rarely when it could be used more often. I don't think there is enough room in the housing for an extra bulb so I am planning to use a couple of diodes to convert the reverse light into a reverse & signal light. The only thing I can't decide on is should I leave the bulb white so that I have a white/yellow turn signal or should I change it so that I end up with yellow reverse lights? Thoughts?
jonathang is offline
