Okay, after going through all the forums looking for help or suggestions regarding HID upgrades for the 2008 WRX 5-Door Wagon, here are a few questions i have.
1. Has anyone done a STI complete conversion into an 08 WRX (Head Unit / Ballast / Bulbs)? Will it work?
2. Are the stock Halogen projector compatible for a straight aftermarket HID conversion without all the glare?
3. Since I've never done a retro fit before, what options do I have for an optimal, OEM look, but with a clean HID light source (no excessive glare)?
4. Looking to spend about $300 to $350, but if it's all OEM products, I may pay more.
Unless the DRL are running off the highs, you will burn the ballast. I've had a HID kit installed on my05 for 4 years without having been stopped once for any light issues. For those who installed the kits, did any of joy disable your DRL's??
After reading everyone's post, I finally got a pair of SharpHID 35W 5000k, but I have a question regarding the way the lights turn on. I was watching a video on their website and I was wondering if all the lights function like the OEM lights, or will this kit override some of the existing lighting functions (ie daylight driving, fog, highbeam) Do I use the standard light switch to turn on my HID, or do I have to install a separate switch?
The lights should operate just as OEM ones do. The kits and battery harness do not modify the DRL settings or anything else on the vehicle. You use the standard headlight switch. The kits are plug and play on these vehicles.
Did anyone have to adjust their headlights to compensate for the HID? Of was the height okay? Mine seems a bit high, unless I'm just not that use to it...
Yes but you only need to buy 1 kit for high beams and one kit for low beams so it should only cost 100 total, and for your housings you need to order the H11 Kit for low beams and the 9005 kit for high beams
Yes but you only need to buy 1 kit for high beams and one kit for low beams so it should only cost total, and for your housings you need to order the H11 Kit for low beams and the 9005 kit for high beams
I was wanting to try this kit out Morimoto Retro-Quik System - Complete Retrofit Kits from The Retrofit Source Inc, as I have a 2000 Celica and currently running a 5k 55w DDM for lows. Has anyone tried these out? Reason I'm wanting a retro kit is because of the glare. Also as a side note, I've never had a problem with melting or discoloring of my headlights or fogs (35W 3.5ks).
If you do go for a true HID kit, I'd highly recommend going with a 6000K color temperature bulb, as that'll have the best light output with bulb color combo that you can get. 5000K is slightly brighter, but it'll have a tint of yellow to it, where 6000K has a tint of blue.
