I'm looking for a higher-end car audio system for my 06' WRX. Any suggestions? What have you all done and within what price range? I was going to buy some Infinity 6010 components for the front and the 6.5 6010's for the rear, but the install guy said they may not fit due to the depth of the speakers. Has anyone else ran into this problem?
I'm not exactly sure if it's the same dimensions as the previous years, but the problem is that it's not deep enough. Spacers will alievate the problem. Any knowledgable audio installer should know what needs to be done. Best Buy even knows to install spacers for Imprezas... although Subarus are everywhere in my town.
I'm not the best person to ask seeing I'm running Subaru's "upgraded" system. If I were to build a system, and I saved up to get the expensive brands I wanted, I'd go with an Alpine head unit, Boston Acoustic speakers/sub, and JL Audio amps... but that's $$ right there. I haven't done much ICE research seeing it's not high on my priorities list.
Just insatalled Alpine typeS 6 1/2 in front and 5 1/2 rear, Sony 4channel amp and Jvc '10 sub in a bandpass box, and Pioneer DEH7700. Not bad for $300 bucks. I installed it myself . The only problem is finding a good ground location in the trunk. I wanted to save money for performance patrs.
blk06wrx, you were able to fit 5 1/2" in the rear? I was told that you need a custom made bracket, usually spacers won't even work. Did you have much problems?
What do you guys think of the Polk db series? They're on sale at crutchfield, was thinking of picking up the 6500 components (6 1/2")and the 400 rears (4"). Thoughts?
You can adapt an amp to your factory head unit with the proper connectors to run subs, just not sure what it is that you need.
