06-07 side marker bulb replacement - Subaru WRX Forum
post #1 of 2 Old 03-11-2009, 09:10 PM Thread Starter
boo-key's Avatar
Well the title pretty much says it all. How do you replace the side marker bulb (in my case passenger side) on a 06-07? I can probably figure it out , but I thought someone might know already. I just dont want to go taking my bumper cover or inner fender off if there is an easier way. Yes I searched it, googled it, and looked in my owners manual. The owners manual tells how to replace almost every bulb except that one.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #2 of 2 Old 03-14-2009, 09:28 PM Thread Starter
boo-key's Avatar
O.K. I figured it out. What I did was raise the vehicle and support it with jack stands.Take the passenger side wheel and tire off. Remove the inner-fender held on by several plastic screwtype and push type clips. Take out the white plastic intake thing (I dont know what this is called. Is this the snorkus?) from inside the fender. It is held in by two 10mm nuts. One is under the hood on the fender , the other is inside the fender. Now you can get to the side marker and turn signal bulbs.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
