06' or 07' ECU pinout - Subaru WRX Forum
post #1 of 13 Old 12-09-2006, 08:54 PM Thread Starter
Hittman is an unknown
Smile 06' or 07' ECU pinout
Hey there,
I just bought an 07' WRX TR a couple of months ago and I bought some gauges for it (a boost gauge and an A/F ratio gauge). I got the boost gauge hooked up and now I am trying to hook up the A/F gauge. But I can't find any ecu pinouts for 06' or 07' to find out which wire is for the rear o2 signal!
I know this is kind of a stupid gauge to have because it isn't real acurate. Being so far back and all.
Anyway! I was wondering if anyone has an ecu pinout, or if anyone knows where to find one for free?
I am going to be buying a pyrometer as well, and need the pinout to know which wires I need to tap in to for that.
Thanks in advance.
Josh (Hittman)
Hittman is offline
post #2 of 13 Old 12-09-2006, 11:58 PM
kh15's Avatar
kh15 is an unknown
nobody has them! i have been looking for an 06 pin out from months now and nothing even close has come up!
kh15 is offline
post #3 of 13 Old 12-10-2006, 03:03 AM
jtodaro's Avatar
jtodaro is an unknown
This tread was just posted on Nasioc a few days ago.
http://forums.nasioc.com/forums/showthread.php?t=1153279
jtodaro is offline
post #4 of 13 Old 12-10-2006, 10:43 AM Thread Starter
Thanks a lot! I will try and get this hooked up as soon as possible and let you know how it goes. If it works I will try and post some pics or vids of my gauge in action.
Thanks.
Josh (Hittman)
'07 WRX TR
Hittman is offline
post #5 of 13 Old 12-10-2006, 11:42 PM
kh15's Avatar
kh15 is an unknown
Thanks.
Josh (Hittman)
please do! i would love to see that!
kh15 is offline
post #6 of 13 Old 12-16-2006, 11:15 PM Thread Starter
It's been too cold lately (around 30 degrees) so it will probably be a while before I get it hooked up. But hopefully I will be able to use my friends garage!
'07 WRX TR
Hittman is offline
post #7 of 13 Old 12-31-2006, 06:09 PM Thread Starter
Well, I finally got this thing hooked up and it is pretty erratic. I'm not sure I like it. I think I need a wide-band A/F gauge.
Anyway, I will still try and get some video posted.
Hittman
'07 WRX TR
Hittman is offline
post #8 of 13 Old 12-31-2006, 08:49 PM
9d2TSi's Avatar
I could've told you that. A/F gauges are lame. Get a wideband if you want accuracy.
As far as a pyrometer (EGT) goes, hook up the power straight to the battery, the backlight to the illumination wire on the radio, and the ground to a known good ground. I wouldn't hook it to a pre-existing ground wire, hook it up to the steering column, there are some bolts there that you can hook it up to.
9d2TSi is offline
post #9 of 13 Old 01-01-2007, 12:04 AM Thread Starter
Thanks for the advice!
As for the video I Promised kh15. Here are a few links.
This one is while I was parked, and this one while I was driving. This gauge looks cool, but is quite useless!
You will need the volume turned up on the first one to tell what is going on between the motor and the gauge. I wouldn't recomend having it too loud for the second, as I didn't have the radio turned down as much as I thought I did.
Enjoy!
Josh (Hittman_1)
'07 WRX TR
Hittman is offline
post #10 of 13 Old 01-01-2007, 09:28 AM
kh15's Avatar
kh15 is an unknown
thank you!
kh15 is offline
post #11 of 13 Old 03-07-2014, 10:59 AM
jcpage305 is an unknown
Does any one have a layout on what plug is what on the 06 ecu? I am trying to find B135 pin 8&9.
jcpage305 is offline
post #12 of 13 Old 03-07-2014, 04:07 PM
boo-key's Avatar
I might. Ill look later tonight.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #13 of 13 Old 03-07-2014, 05:06 PM
boo-key's Avatar
Pm me a email and ill send you what I found.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
