04FogLights - Subaru WRX Forum
post #1 of 2 Old 01-25-2005, 03:08 PM Thread Starter
04FogLights
Does anyone have instructions on how to change the fog lights on 04 wrx? Do i need to take off bumper or just that cover?
chopstix is offline
post #2 of 2 Old 01-25-2005, 04:38 PM
Ian
Ian's Avatar
Send a message via AIM to Ian
You have to remove the cover and go under the car and pull down the black plastic splash guard, you will have to remove a couple of clips to do that, not the whole thing just the part under the fog lights. Once you pull that section out of the way you will see 2 bolts, remove those and then you should be able to pull out the fog lights from the front of the car to get easier access to change the bulb.
good luck!
Ian is offline
