04 fog light - Subaru WRX Forum
post #1 of 3 Old 08-15-2004, 09:21 PM Thread Starter
wags528's Avatar
wags528 is an unknown
Send a message via AIM to wags528
04 fog light
anyone know how to change the bulbs in the fog lights on an 04 or 05 wrx - i want to swap mine out for some yellow halogens maybe? . . but the manual says consult dealer for installation . . . .
wags528 is offline
post #2 of 3 Old 08-15-2004, 11:59 PM
cannibal86 is an unknown
foglight replacement...
Here, try this:
cannibal86 is offline
post #3 of 3 Old 10-07-2004, 03:13 PM
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
Remove fog light cover by carefuly useing a screw driver and pry in the little slot on the sides and they will pop right out. Then from under the car you have to remove a couple of the push in clips, with some force you can pull back the bottom of the skirt to get access to the 2 bolts that hold them in. Once you remove the 2 bolts from each side you then can wiggle or pull the fog light out and unplug the fog light to change the bulb. Just a reminder not to touch the bulb itself or it will die alot sooner, good luck
Ian is offline
