Yankie Help required for Down Under Bloke - Subaru WRX Forum
post #1 of 10 Old 09-18-2008, 04:25 AM Thread Starter
STi 22B's Avatar
STi 22B is an unknown
Send a message via Skype™ to STi 22B
G'Day all,
I need some help and I have just about tried everything I have a 2001 WRX with a standard EJ20 Turbo engine but just recently the car as developed a missing problem !Cry! The car is firing on #3 and #4 cylinders only. I found the #1 and #2 just have decided to go on a walk-about (must be lost out bush somewhere? LoL) I have 12v power to the coils and I have tried fitting 2 new coils to no avail. I have also tried fitting another ECU and this has done nothing to change the situation
Please can anyone help with a wiring diagram or any ideas?
Cheers,
STi 22B is offline
post #2 of 10 Old 09-18-2008, 11:35 AM
Try doing a compression test.Also try swaping the injectors on those cylinders with the injectors on the cylinders not missfiring.If the missfires change from the #1 & #2 to the #3 & #4 then you know it was the injectors.
dumdum is offline
post #3 of 10 Old 09-18-2008, 02:38 PM
bocaks's Avatar
bocaks is an unknown
you never stated if you had spark after trying new coils. do the poor man test, pull the plug and hold it to the block and crank the motor over. no spark. probably wiring. if their is spark then check fuel and air like injectors or maybe the tgv butterflys are malfunctioning. but if you got spark it has to be one of the other needs of combustion. mine sounded like it had the worst cam job ever when i had some bent valves. it sounded like it was missing on the one side. but i knew what had happened.
needs of combustion are air, fuel, comprestion and spark. its a pump make sure it can breathe.
its all coming together, after a year.
02 WRX
bocaks is offline
post #4 of 10 Old 09-18-2008, 02:49 PM
bocaks's Avatar
I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post! I will not double post!
02 WRX
bocaks is offline
post #5 of 10 Old 09-18-2008, 07:49 PM
Squamr's Avatar
Squamr is an unknown
Do you have any mods? If so, please post them ALL, as well as what CEL codes you are showing if any. Our high performance engines are a royal b#tch sometimes, but if we put our heads together we should be able to help each other diagnose the prob.
Squamr is offline
post #6 of 10 Old 09-19-2008, 08:18 AM Thread Starter
STi 22B's Avatar
Cheers Guys... to answer a few questions,
1. I tried 2 new coils to no avail (I'm sure I mentioned this before, sorry)
2. I have Injector pulse and fuel into the cylinders (1 & 2)
3. The engine is fully rebuilt and this is the first time it has been run (compression is even over all 4)
4. No Check Engine Codes but light is on when engine is running?? (used a Snap-On Scanner to search for codes)
5. Only Mods are a VF22, FMIC, UniChip and equal length exhaust headers.
I have spent the last 2 days trying to fix this Bucket of S..t. Sorry it's just starting to piss me off, I do really love the car.
Please help and thanks to those who are trying to help, please keep the ideas coming
STi 22B is offline
post #7 of 10 Old 09-20-2008, 08:02 AM Thread Starter
STi 22B's Avatar
Real big THANKS to you guys
I feel like a bit of dickhead for not checking the basics (fuel, spark, compression)
I have spent almost 2 days trying to find out why I had no spark in 1 & 2 after pulling off the power leads to the coils??? After about 6 Jim Beams, I thought about the things you guys had mentioned... This is where I try and hide my face in my shirt... I put my noid light in # 1 injector to find I had no pulse!! But I do if I put the engine under load??? bit more investigating, lead me to find the the IACV and crapped itself (thank god I had a B4 Legacy on hand to try a spare one) now I just have to go out Monday and buy myself another one.
Once again, thanks all for your help
STi 22B is offline
post #8 of 10 Old 09-21-2008, 03:06 PM
So you got it figured out? Thats great to hear man.
post #9 of 10 Old 09-22-2008, 12:07 PM
Awesome...glad to hear the 22B will be back up and running. Wish those cars made it to our shores. Btw, what is a IACV?
post #10 of 10 Old 09-22-2008, 12:50 PM
If he's got an EJ20, it ain't a 22B...
