Won't Start After Turbo Back Install - Subaru WRX Forum
post #1 of 5 Old 05-26-2013, 10:49 PM Thread Starter
petrone1050 is an unknown
Installed turbo back exhaust. Had to remove Intercooler to tighten one of the bolts. When completed started car no problem and check for exhaust leaks. Borla Hush sounded sweet. Restarted car to roll off of ramp into drive way again no problem. When I attempted to start the car to move out of driveway it cranked but nothing happened (turned over but would not fire). I read searches rechecked all the connectors I may have bumped. Attempted to start still no joy. Bumped ignition several times and heard it try to fire. Went thru sequence fuel pump attempt to start for 2 seconds (about two turns is the usual) . On about try 5 or 6 she caught and fired up. I move the car turned off and restarted. Drove around the block came back to the house. Parked, turned off and attempted restart again no joy. All help welcome.
petrone1050 is offline
post #2 of 5 Old 05-27-2013, 12:08 AM
Any engine management? Any way to monitor? These are longshots
post #3 of 5 Old 05-27-2013, 10:34 AM Thread Starter
I have a Cobb accessport that will pull codes but right now there is no CEL showing.
post #4 of 5 Old 05-27-2013, 02:15 PM
Have you checked the fuel pressure and/or the fuel filters?
post #5 of 5 Old 05-27-2013, 06:55 PM Thread Starter
Got some advice on another forum. Disconnect battery and let ECU reset. It worked. Must have had some sensor that was unhappy and resetting power got it back inline. Thanks for your suggestions
