wierd stalling issue - Subaru WRX Forum
post #1 of 17 Old 06-09-2009, 04:58 AM Thread Starter
scoobyrooftw's Avatar
scoobyrooftw is an unknown
today on my way to work when i stopped at the first stop sign of the trip my car stalled. i had the clutch pushed in plenty early. the engine just cut out. it started right back up and drove normal the rest of the way. this is the second time its done it at the same stop sign. the engine wasnt quite warmed up yet. any ideas what it could be?
scoobyrooftw is offline
post #2 of 17 Old 06-09-2009, 07:36 AM
JimmyJ is an unknown
Aftermarket bov maybe, always let you're car warm up before driving, especially a turbo car.....
JimmyJ is offline
post #3 of 17 Old 06-09-2009, 08:43 AM Thread Starter
i have an aftermarket bov on it. how much should i let it warm up? the whole way?
post #4 of 17 Old 06-09-2009, 09:11 AM
Unfortunately, that's your best bet.
post #5 of 17 Old 06-09-2009, 10:53 AM
04paulieWRX's Avatar
04paulieWRX is an unknown
your mod list doesn't include a type of em. having an em could smooth out your car and help you with this isssue
04paulieWRX is offline
post #6 of 17 Old 06-09-2009, 01:59 PM
But it wont solve the BOV issue at all. Both you and your car will like it alot more if you let it warm up also.
post #7 of 17 Old 06-09-2009, 08:41 PM
03 CrazyTaxi's Avatar
It almost sounds like you have a lightweight flywheel... I'm not familiar with the BOV in your mods list. Is it a 50/50 or full atmospheric? If it's an atmospheric, I would highly recommend going back to the stock one.
03 CrazyTaxi is offline
post #8 of 17 Old 06-09-2009, 11:55 PM
I bet your BOV needs to be adjusted. It doesn't have enough tension on the spring to hold it closed at idle. Put the stocker back on.
Kjott21 is offline
post #9 of 17 Old 06-10-2009, 06:16 AM
The Perrin VTA is a full atmospheric BOV
post #10 of 17 Old 06-10-2009, 08:48 AM Thread Starter
i dont have the stock bpv because there was already a bov on the car when i got it. idk aobut the lightweight flywheel. the dealer i got it from said the guy who traded it in had just replaced the clutch with a stage 2 clutch. dunno who makes it or if he did the flywheel too. why would a lightweight flywheel make it stall like that?
oh and as soon as i save up enough money im getting a protune. ###### another month or so
post #11 of 17 Old 06-10-2009, 09:32 AM
Oh man... that stage 2 clutch might be too much if your transmission is still stock. Be careful if that's the case. Two main rules of thumb for these cars are: (1) stock transmission + stock clutch, and (2) no aftermarket bov until you NEED one - a.k.a. highly modded to the point where you need something to handle more pressure. Otherwise, you risk running into some very expensive problems.
post #12 of 17 Old 06-10-2009, 09:50 AM
Flywheel has nothing to do with his issue.Reread his first post.Flywheel would be when trying to actually move the car not when you pushing the clutch in on deceleration.Warming up the car won't help either.It probably has to do with the BOV not set right or his IAC valve needs cleaning.
dumdum is offline
post #13 of 17 Old 06-10-2009, 05:25 PM Thread Starter
what would the bov being set wrong do?
post #14 of 17 Old 06-10-2009, 05:35 PM
I agree with the BOV and the IAC but have to disagree with the flywheel not being a possible cause. When there is an ultralight flywheel on the car and you press the clutch in, there isn't enough rotating mass to gradually slow the engine down to idle. Instead it plummets quicker than the engine expects and can stall. I had it happen with my old 12lb flywheel and replaced it on the advice from 2 Subaru tuners.
post #15 of 17 Old 06-10-2009, 05:51 PM Thread Starter
where exactly is the IAC valve located? a picture would be very helpful
