Wierd... chirping sound @WOT(04 WRX). - Subaru WRX Forum
post #1 of 12 Old 06-07-2009, 12:26 AM Thread Starter
Ok, first let me say that I'm a noob to Subaru. I've been a mechanic for about 4 years so I do know my way around an engine well. Also, I have not had a lot of time to even mess with this car since I bought it Monday.
Anyway... in 1st gear at half to full throttle I hear an odd, high pitched noise that is constant. Then, with the same throttle application in 2nd, the sound becomes "pulsed" very consistently; like a chirp. Same sound in third and probably 4th and 5th but by then there is too much road noise to hear it. It's very hard to describe the sound. It's not like a belt but more of maybe an air passage or leak, perhaps. Anyway, it's very noticeable and it happens every time.
It's not really bothersome but it just sounds... like something is malfunctioning. Also the car does seem a bit sluggish but I'm not exactly sure how it should feel. As I said, subie noob.
Is this normal? Could it be the normal sound of the boost control system?
By the way, the car is stock. It makes max ~11lbs of boost(unsure of specified rating). I checked the inlet tube, discharge pipes and all clamps, connections from the filter to the throttle body and everything is in good shape.
Nick. '90 Taurus SHO. Forged, Turbocharged, intercooled, meth, ~430whp. 12.93 @ 116 - FWD FTL.
nik97 is offline
post #2 of 12 Old 06-07-2009, 11:36 AM
jdowrx's Avatar
Sounds like an exhaust leak to me. My car did the same high pitched noise and it ended up being the gasket between the turbo and downpipe. I believe the stock boost should be around 13.5lbs, 11 seems low.
jdowrx is offline
post #3 of 12 Old 06-07-2009, 01:47 PM
03 CrazyTaxi's Avatar
Check for exhaust leaks and vacuum leaks. Boost seems low for a stock 04 but that may be caused by an exhaust leak.
03 CrazyTaxi is offline
post #4 of 12 Old 06-07-2009, 02:28 PM Thread Starter
Thanks guys. Come to think of it, I have heard some very strange exhaust leaks on n/a cars. Perhaps the pulse sound is due to waste gate actuation... I plan on installing an up/down pipe soon so I may find the problem then.
Correct me if I am wrong here but the computer and solenoid should be able to maintain a proper boost setting and compensate for wear, minor leaks, altitude changes etc... Yes? Where do people usually start looking when the have low boost on these cars?
nik97 is offline
post #5 of 12 Old 06-08-2009, 08:26 PM
Typically, between the header and uppipe or the uppipe and turbo. That's basically the 2 most likely places.
post #6 of 12 Old 06-09-2009, 08:53 AM
And please make sure you use the stock style gaskets when replacing your uppipe. Those are best for preventing leaks.
post #7 of 12 Old 11-14-2009, 12:42 PM
VTrider36's Avatar
Send a message via AIM to VTrider36
Now i have a similar problem, and these ideas sound good. My chirping noise comes into play in 4th and 5th under very light-medium throttle, and i don't notice anything in lower gears. Plus it never happens at idle. Any ideas? Boost or exhaust leaks there too?
VTrider36 is offline
post #8 of 12 Old 11-16-2009, 12:55 PM
Um, your car doesn't have a turbo VTrider. So, boost issues aren't related. Maybe its your AEM short ram chirping or you exhaust leaking. IDK, at this point.
post #9 of 12 Old 11-16-2009, 07:14 PM
You also might want to have your muffler bearings checked out. Those can get worn out and start to chirp....
-Randy
post #10 of 12 Old 11-17-2009, 07:41 PM
VTrider36's Avatar
yea, forgot to mention, i have a 04 wrx, which has a turbo
the GC is my other car. Havent had time to update pics
post #11 of 12 Old 11-18-2009, 06:59 PM
That makes more sense then. I wasn't trying to be a a-hole. Someone, should be able to know more
post #12 of 12 Old 11-18-2009, 08:23 PM
i was on the other hand trying to be a smart ass....and i apoligize.
-Randy
