White Spark Plugs - Subaru WRX Forum
post #1 of 7 Old 07-17-2004, 11:30 PM Thread Starter
Noogin's Avatar
Noogin is an unknown
Send a message via AIM to Noogin
Question White Spark Plugs
Well, when I changed my plugs the other day they were all a frosted white color like my engine is running real lean. I no longer have an aem short ram on the car because I heard that it is what caused the lean condition. Now that the stock intake (minus silencer) is on the car and with running 1 bar of boost (14.5 psi) my egt is hitting about 790 degrees celsius (which is about 1450 degrees farenheit). I was never able to get an egt reading with the intake on because i didn't have the gauge yet. I just wanted to make sure that my car is not running to lean. Any suggestions would help.
THanks for your time
Noogin
Noogin is offline
post #2 of 7 Old 07-19-2004, 08:41 PM
fc735's Avatar
those EGT's are a little high.....what kind of management?
shouldnt be too bad though, as long as you arent gettng flakes of aluminum on the plug, you are fine!
fc735 is offline
post #3 of 7 Old 07-20-2004, 08:07 AM
BlueDemon's Avatar
BlueDemon is known to be trustworthy and helpful BlueDemon is known to be trustworthy and helpful
750 C. is not a high EGT, especially if that is at WOT. Try to keep it below 820-830 at WOT and you "should" be fine. Things start going "Boom" above and beyond those temperatures.
Blue
BlueDemon is offline
post #4 of 7 Old 07-20-2004, 08:09 AM
fc735's Avatar
750 is fine...but 790 is getting a litte close for comfort, esp if he doesnt have any kind of tweakbility in his system....
eh, oh well.....leaner=more power right?!
fc735 is offline
post #5 of 7 Old 07-20-2004, 10:52 AM Thread Starter
Noogin's Avatar
Yea, the 790 is at WOT and the only control I have is boost right now with a stock ecu. I know I know, get some managment but its hard making "The Decision" on what to get. I turned my boost down to about stock and hopfully with the POS intake gone, ill be ok until i do managment. I just wanted your opinions because you guys have helped me out with every querstion or problem I've come across.
Thanks again!!!!
Noogin
*by the way, i can chip away flakes off my plug, just alittle. Yet thos plugs had like 35000 miles with a intake. oops
Noogin is offline
post #6 of 7 Old 07-20-2004, 01:51 PM
BlueDemon's Avatar
790 cruising I would say is too high. However, if you're at the track and you do a quarter mile, you are most likely going to hit 1600 F for a quarter of a second or so. Unless you have a PERFECT tune, or you're running too rich, it's just plain going to happen.
Hitting a high EGT for a split second isn't going to kill your engine. It's crusing for long periods at above normal temps which will do it.
Blue
post #7 of 7 Old 07-20-2004, 11:24 PM Thread Starter
Noogin's Avatar
Ight cool man, thanks. it cleared up alot of confusion i had. What would be the advantage of running a colder plug because I am running stock heat right now?
Thanks
Noogin
Noogin is offline
