Well, when I changed my plugs the other day they were all a frosted white color like my engine is running real lean. I no longer have an aem short ram on the car because I heard that it is what caused the lean condition. Now that the stock intake (minus silencer) is on the car and with running 1 bar of boost (14.5 psi) my egt is hitting about 790 degrees celsius (which is about 1450 degrees farenheit). I was never able to get an egt reading with the intake on because i didn't have the gauge yet. I just wanted to make sure that my car is not running to lean. Any suggestions would help.
750 C. is not a high EGT, especially if that is at WOT. Try to keep it below 820-830 at WOT and you "should" be fine. Things start going "Boom" above and beyond those temperatures.
Yea, the 790 is at WOT and the only control I have is boost right now with a stock ecu. I know I know, get some managment but its hard making "The Decision" on what to get. I turned my boost down to about stock and hopfully with the POS intake gone, ill be ok until i do managment. I just wanted your opinions because you guys have helped me out with every querstion or problem I've come across.
Thanks again!!!! !Thumbs Up
Noogin
*by the way, i can chip away flakes off my plug, just alittle. Yet thos plugs had like 35000 miles with a intake. oops
790 cruising I would say is too high. However, if you're at the track and you do a quarter mile, you are most likely going to hit 1600 F for a quarter of a second or so. Unless you have a PERFECT tune, or you're running too rich, it's just plain going to happen.
Hitting a high EGT for a split second isn't going to kill your engine. It's crusing for long periods at above normal temps which will do it.
Ight cool man, thanks. it cleared up alot of confusion i had. What would be the advantage of running a colder plug because I am running stock heat right now?
Thanks
Noogin
