white smoke coming from turbo area - Subaru WRX Forum
post #1 of 18 Old 04-12-2006, 11:11 AM Thread Starter
dumb_1 is an unknown
Send a message via AIM to dumb_1 Send a message via Yahoo to dumb_1
Question white smoke coming from turbo area
I was driving in traffic when I pulled up to stoplight ,I noticed white smoke coming out of hood scoop . I pulled in & raised the hood , looked like smoke is coming from turbo area/down pipe area. It smells like oil burning on an exhaust . I got a flashlight & cant find any leaks ,even minor ones . I ended up driving more last night & this morning with no leaks or smoke . Has anyone had similar problem . car is 03 wrx sedan .
dumb_1 is offline
post #2 of 18 Old 04-12-2006, 01:04 PM
Nose Nuggets's Avatar
well. thats odd. burning oil going to make black smoke. usualy you never see white 'smoke'. its usualy steem. if you saw steem coming from your turbo it could be the cooling system.
Nose Nuggets is offline
post #3 of 18 Old 04-12-2006, 02:51 PM Thread Starter
Its smoke, not steam(the best I can tell) . The weird thing , its not doing it now . I wonder if some plastic or rubber may have gotten loose & gotten caught up in the heat shields. The smell is usually similar to oil burning .
dumb_1 is offline
post #4 of 18 Old 04-12-2006, 02:56 PM
nick4592's Avatar
WD-40?....that burns white
nick4592 is offline
post #5 of 18 Old 04-12-2006, 02:59 PM Thread Starter
I haven't used any WD-40 ,or done any repair/maintenance in weeks .
dumb_1 is offline
post #6 of 18 Old 04-12-2006, 03:45 PM
holy shit, really? does all motor oil burn white...
post #7 of 18 Old 04-13-2006, 07:33 AM
nick4592's Avatar
Ha ha..not motor oil....Wd-40 or liquid wrench things like that from my experience burn white off the turbo and such
nick4592 is offline
post #8 of 18 Old 04-13-2006, 12:12 PM
. i just saw the w-40
hahahahahahahahahahaahaha
im going back to bed....
post #9 of 18 Old 04-14-2006, 06:27 PM
03 CrazyTaxi's Avatar
The only time I've seen something similar is when I've been through a car wash and water got in the hood scoop. Might be the turbo bearings
03 CrazyTaxi is offline
post #10 of 18 Old 04-14-2006, 07:50 PM
nick4592's Avatar
That would be a wicked awful sound and black smoke outta the exhaust
nick4592 is offline
post #11 of 18 Old 04-14-2006, 10:05 PM
Sorry, I guess I should have clarified that a bit. If you have too much oil getting to the bearings, the excess has to go somewhere. Typically, it will burn off. The sound and black smoke comes from too little oil and your bearings seize up.
post #12 of 18 Old 04-15-2006, 09:46 AM
nick4592's Avatar
Indeed
nick4592 is offline
post #13 of 18 Old 06-17-2011, 12:13 PM
dom0nec is an unknown
hey i am having that same problem now. My friend also had that problem and it was his oil return line.
dom0nec is offline
post #14 of 18 Old 06-17-2011, 10:02 PM
What did he do to fix it? Just replace the oil return line? Was it clogged or what?
post #15 of 18 Old 06-19-2011, 12:22 PM
bad grocerygetter's Avatar
Well i see you said its smoke not steam but my first thought is was the ac running? Mine was dripping on the dp at one point and did that. Also had the turbo coolant line blow another day and got that. That was a scary day. Made a smallish pop then white steam out the scoop. Til i looked at it i was sweating bullets. Good luck
Kevin.
bad grocerygetter is offline
