where can i get Oxygen sensor Dummys? - Subaru WRX Forum
post #1 of 11 Old 03-25-2009, 01:42 PM Thread Starter
Eric2002wrx's Avatar
Eric2002wrx is an unknown
Since my exhaust is all done its throwing p0031 p1131 p0037
Eric2002wrx is offline
post #2 of 11 Old 03-25-2009, 07:18 PM
P0031 =Front oxygen (A/F) sensor heater circuit low input
P0037 =Rear oxygen sensor heater circuit malfunction
P1131 =Front oxygen sensor circuit malfunction (short circuit)
Im guessing some sort of EM will be the cure. Is this a CBE or a TBE? And what are all your mods?
post #3 of 11 Old 03-25-2009, 08:22 PM
03 CrazyTaxi's Avatar
A simple stage 2 tune would fix your problems and give you the power gain you are really after. The O2 spacers would only be a bandaid.
03 CrazyTaxi is offline
post #4 of 11 Old 03-27-2009, 01:46 PM
dubrex2002's Avatar
dubrex2002 is an unknown
Send a message via AIM to dubrex2002
you can go to advance/autozone and tell them your looking for spark plug nonfoulers. but you want them to fit an 02 sensor. they should be around $3-4. it will come with 2 of them..take one and drill it out with a 1/2 inch bit. put that one on the 02 sensor.then put the one you didnt drill out on top of that one.then screw it into the exhaust..its a cheap fix.i have a catless uppipe/downpipe and str8piped and have not seen the check engine light yet.
this is what they look like when you buy them
this is when you drill one out with a 1/2in bit-and put on 02 sensor
and this is the finished product-not screwed into the exhaust yet
-sounds like a boat-
dubrex2002 is offline
post #5 of 11 Old 03-27-2009, 04:39 PM
Do not do this to the front O2 sensor....................
dumdum is offline
post #6 of 11 Old 03-28-2009, 11:22 AM
dubrex2002's Avatar
why not?
post #7 of 11 Old 03-28-2009, 04:57 PM
im guessing because the sensor is not being deleted, it could tell cause the CEL to come back and car may run like poop? just throwing a non-educated guess. haha. i would just the an 02 delete or a tune which IMO is the right way to do it.
post #8 of 11 Old 03-28-2009, 06:54 PM
Originally Posted by dubrex2002 View Post
why not?
Because the front sensor is the main AFR sensor.If you use those anitfoulers you will screw up the reading to that sensor as well as your engine.The secondary cat efficiency sensor is the one EM fixes not the front sensor.Something is wrong with your sensor...........
dumdum is offline
post #9 of 11 Old 03-28-2009, 09:42 PM Thread Starter
i took it in to AMS performance they specialize in in evos and wrx sti's they did a dyno tune and removed the codes completely and now im really feeling the poines
post #10 of 11 Old 03-28-2009, 10:02 PM
Yay! A noob who actually listened!
post #11 of 11 Old 03-30-2009, 02:24 AM
dubrex2002's Avatar
i do not have the nonfoulers on the first sensor..but its good to know that its an A/F sensor
